Thread: Cover pump
    Default Re: Cover pump
    I like the electric pump that cost about $70 from Lowes. Hooks to a Garden hose.
    pool newby is offline ** No working email address ** Thread Analyst pool newby 0
    Thanks for the replies, I had an old garden hose that I was going to toss anyway, and cut it to size, and the siphon method is working like a charm. I'm always ready to save $$$ anywhere possible. Now, I just gotta watch it, and make sure I leave about an inch on top, and don't drain the whole thing.
    Bob P
    E Tn
    pool newby
    As I've been dealing with a leaky pool since closing, I've had lots of time to perfect my cover draining skills (always look on the bright side, right?)
    I've been using my pool vacuum hose as the siphon hose, getting it started with suction from a small wet/dry vac. Works like a charm. You just have to keep the vac hose under water of course not to lose suction. Once you get it set, the water is gone lickety split.
  1. pool cover pump
    By Barry J in forum Pool Equipment & Operations
    Last Post: 09-29-2011, 06:19 PM
  2. Pump water off cover
    By day1 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-24-2007, 03:34 PM
  3. pump for cover
    By Sean-NJ in forum Pool Equipment & Operations
    Last Post: 11-23-2006, 08:22 PM
  4. can U operate pump with cover on?
    By powiebaby in forum Pool Equipment & Operations
    Last Post: 09-01-2006, 10:49 AM
  5. Does the pool pump need a cover?
    By west1745 in forum Pool Equipment & Operations
    Last Post: 07-27-2006, 09:48 AM
