Results 1 to 8 of 8
Thread: Clorox Regular
    Charlotte, NC
    Default Clorox Regular
    I bought some jugs at Costco recently that are labeled as 6%. However, there is a note that says that it will yield 5.7% available chlorine. Anyone know why the yield is diminished?
    California
    Default Re: Clorox Regular
    The 6% refers to the Weight % of Sodium Hypochlorite. The % Available Chlorine is the equivalent weight % of chlorine gas which is the standard (defined as 100%) used for all chlorine measurements, including Free Chlorine (FC) level. The molecular weight of Sodium Hypochlorite (NaOCl) is 74.4422 while the molecular weight of chlorine gas (Cl2) is 70.906 so the formula is:
    Weight % Available Chlorine = Weight % Sodium Hypochlorite * (70.906 / 74.4422)
    Since 74.4422/70.906 = 1.050 it's easier to remember to just divide the weight % by 1.05 to get % available chlorine. 6% / 1.05 = 5.7%
    So Clorox did not lower their chlorine level when they simply added the clarification that their 6% bleach yielded 5.7% available chlorine.
    To make matters even more confusing, there is another quantity called "Trade %" which is often used to measure chlorinating liquid. The Trade % is the volume % of available chlorine so this is related to the weight % of available chlorine by the density (specific gravity) of the liquid as follows:
    Trade % = Weight % Available Chlorine * Specific Gravity
    The density of clorox regular bleach is about 1.1 so the Trade % is 5.7% * 1.1 = 6.3%. It is this trade % that is most accurately used for BleachCalc since it is the % of available chlorine (in similar units as FC) per volume of liquid. So, 1 gallon of 6.3% (trade) bleach would give 6.3 ppm FC in 10,000 gallons of water. The density of 12.5% chlorinating liquid is around 1.16 due to the higher dissolved chlorine and the extra "dense" base (sodium hydroxide) that is added.
    Richard
    Charlotte, NC
    Thanks Richard.
    Sanford, FL
    Quote Originally Posted by chem geek View Post
    Richard
    ....... uh you totally got me on this one . So you use 6.3% in bleach calc - but no normal human would be able to deduce that was the *actual* percentage of chlorine. So glad I use a SWCG
    Completed 8/21/06
    14,000 gallon 3'-6' concrete pool with Diamond Brite
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Hayward Super II Pump - Cartridge filter
    See pictures here http://www.philsimmons.com/family/ga...mages&keyword=
    California
    Quote Originally Posted by Simmons99 View Post
    Well, given the uncertainties of measurements (including pool volume, test kit accuracy, etc.) it doesn't really matter whether you used 5.7%, 6% or 6.3% in BleachCalc since you are going to end up with reasonably close-to-target amounts of chlorine for any of these. The error between 5.7% and 6.3% is only 10% and I don't think anyone is trying to target their FC levels to be that accurate so even though I present the technically accurate information, you can ignore such dribble for practical purposes.
    Richard
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    Richard,
    LOL --- Your dribble represents a very important lesson in chemistry that most people are learning ---- they just don't know it yet
    Keep it coming, I, for one, read every one of your posts & since I have found myself saying, "Richard had an interesting tidbit about that" or " I saw a chart that Richard made --- somewhere" ----I now print most for further review.
    Sanford, FL
    Richard,
    Don't get me wrong - I LOVE your posts - they are so full of logic (which I like). Sometimes my brain cannot process it all - and this post I was actually laughing - because it is SO you
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
  1. Regular use of copper as an algaecide ...
    By paulshikleejr in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-22-2011, 03:34 PM
  2. Regular bleach?
    By swimster in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-13-2010, 11:23 PM
  3. Clorox Regular bleach is slippery
    By CandyMoss in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-18-2010, 03:37 PM
  4. PerFlex or regular DE ??? Which is better?
    By cvoss in forum In-Ground Pool Construction and Repair
    Last Post: 08-01-2006, 07:27 PM
  5. regular maintenance help
    By poolhelp101 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-16-2006, 09:36 AM
