Results 1 to 10 of 17
Thread: Backwash hose ideas??
    Default Re: Backwash hose ideas??
    Mine is plumbed into the sewer line but I have seen set ups where the line is run to the cleanout
    You don't mean the same line that your toilet runs to do you. Our township is pretty strict about adding water to the sewage system unneccesarily. Storm sewer would probably be OK.
    Carterville,IL
    Very simple and hidden is to use 2" pvc piping. By the coupling and glue them all together until you get your 25'. I bought the angled one for the end and and attached a piece that would take the screw cap for the winter months. I used my tiller with the two end tines off and tilled up the yard about 4-6 inches deep and buried it. Under the angled piece that sticks up out of the ground close to the filter, I placed 1 red brick behind and up against it for stability while I backfilled around it. This allows us to use only about a 4-5 ft hose that inserts into the angled attachment and flows nicely to the woods.
    At your hardware store study the parts...you'll get it.
    Good luck.
    I'd attach a photo, but it's mostly under the ground HA HA
    30' Esther Williams Classic Granite
    Installed july 2006
    ~~ Update ~~
    I still have not done anything.
    But I tried to be macho and had my wife turn on the pump while I hold the hose on the other end.
    End results was a mess and I got wet.
    Let me tell you, it is a pain in the @$$ holding that hose and then putting it up.
    Man I really want to get away from this hose. I was told that Home Depot sells some what like a water hose that goes from your filter backwash connection and there is a nozel on the other end that you spray like a gun.
    Is this BS or not? Is there something like that???
    Many thanks for all the great ideas.
    Yes I am a newbie
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
    Anyone here know if you could use an pool vacuum hose as your backwash hose??
    Like this: http://www.cheappoolproducts.com/Swi...0~product.html
    Yes I am a newbie
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    Mandeville, LA, USA.
    According to Waste you can (about five posts up) and I've yet to see him steer anyone wrong.
    Quote Originally Posted by KurtV View Post
    I must of missed that one. I'll give that a shot.
    Yes I am a newbie
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    Cool Re: Backwash hose ideas??
    Mike, if you go with the vac hose, be sure to put the 'vac head end' at the effluent end (the end that 'swivles' will make a huge puddle if connected to the multiport). Also secure it with a SS clamp to keep it from getting blasted off.
    (Thanks Kurt!)
  1. popped backwash hose near end of hose
    By Gretzky99 in forum Pool Equipment & Operations
    Last Post: 05-22-2013, 10:30 PM
  2. Backwash waste uses & routing - I need some help and ideas!
    By zephans in forum Pool Equipment & Operations
    Last Post: 07-12-2007, 03:21 PM
  3. Leak out of backwash hose...
    By sc-pierce in forum Pool Equipment & Operations
    Last Post: 08-02-2006, 10:45 PM
  4. Using backwash hose ?
    By pool newby in forum Pool Equipment & Operations
    Last Post: 07-31-2006, 04:00 PM
  5. Reduction of Backwash water loss ideas.
    By JohnT in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 07:30 PM
