Thread: impeller cavitating
    Question impeller cavitating
    I noticed that my pressure gage has not increased since I had the pool installed in June. It is at about 3 1/2 PSI on low speed and about 13 1/2 PSI on high. If I block the frow of water at the return on low speed it will rise to about10 PSI then drop back down while I am still blocking the flow. Is this normal? It's a Clearwater 2600 sand filter W/ what they claim as a 2 speed 2.5 HP 120v pump.
    Darrell W. -------------------------------------------------------------------
    Man!,this water is cold!
    9,240 Gallon
    15'X 26'above ground
    Using BBB method of chemistry
    Hayward X-Stream 100sq ft cartridge filter
    Hayward 1hp Matrix pump
    Daytona Beach,FL.
    Default Re: impeller cavitating
    What happens inside the pump? Does it start to get a big airspace under the lid?
    Does it stay filled with water but nothing comes out of the return?
    It sounds pretty normal, but if you get a big air space under the lid while blocking the skimmer, then you have a suction side leak, it could be the lid gasket or anywhere along the line from skimmer to pump intake.
    No, it does'nt form air under the lid.
    It just seems to me that if you say put your finger in the return jet that the pressure gage should rise higher then 10PSI. and not drop off. I would think that once the sand starts to trap enough debris to raise the gage to around 10PSI that the filter would just stop working.
    9,240 Gallon
    Daytona Beach,FL.
  1. Possible Impeller Problem
    By godstreasures1 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-09-2008, 04:55 PM
  2. How to Remove Impeller off Motor
    By colby in forum Pool Equipment & Operations
    Last Post: 08-11-2007, 10:07 AM
  3. Cleaning out pump impeller
    By day1 in forum Pool Equipment & Operations
    Last Post: 06-03-2007, 12:42 AM
  4. Removing Hydropump Impeller
    By GWNorth in forum Pool Equipment & Operations
    Last Post: 09-29-2006, 03:25 AM
  5. Help with clogged impeller
    By pool newby in forum Pool Equipment & Operations
    Last Post: 07-17-2006, 11:54 PM
