Closed Thread
Thread: Closing pool
    Frederick,Md
    Default Closing pool
    Does anybody have any experience closing Ig gunite two skimmers, two returns, de filter and draining pump. Would like to save my $300.
    25000 IG gunite.
    Honesdale PA
    Default Re: Closing pool
    As far as I know the closing procedure doesn't matter whether you have a gunite or vinyl lined pool. Everything I've seen on this forum over many years deals with protecting the 'common' parts. Piping, skimmers, filter, pump, chemistry, etc. One area of concern that vinyl people have is the water table. Vinyl liners are more sensitive to 'floating' than a gunite pool. All it takes is a little negative pressure to float a liner but because of the weight, much more to pop a gunite pool out of the ground. There are a couple sticky posts at the top of this forum dealing with closing AG & IG pools. Any questions, please don't hesitate to ask.
Closed Thread
  1. Closing a.g. Pool
    By willis1 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-15-2012, 11:23 PM
  2. closing AG pool
    By UNITY520 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-05-2012, 05:29 PM
  3. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  4. Closing Pool the BBB way
    By DavidP77 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-21-2007, 10:26 PM
  5. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 10:50 PM
