Results 1 to 10 of 10
Thread: When to let Cl come down after opening
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    Default Re: When to let Cl come down after opening
    This is were i'm at tonight:
    FC-15
    CC-0
    ph-7.2
    alk-115
    cya-60
    ch-210
    salt-3000
    temp. 68
    Is there anything I need to change. I have a IG vinyl, heater also.
    Thanks,
    Dave
    duraleigh Guest
    Quote Originally Posted by Davenj
    FC-15
    CC-0
    ph-7.2
    alk-115
    cya-60
    ch-210
    salt-3000
    temp. 68
    Thanks,
    Dave
    Hi, Dave,
    Yeah, your gonna need to change something......Clear out an extra shelf in the fridge and put more beer in it....you'll need it this Summer because your pool is virtually perfect and your buddies will all be over for a swim!!
    Dave S.
    If your pool isn't clear, then keep at it. Is the cloudiness white or brown? Are you vacuuming and brushing everyday? (until the pool is good to go)
    Jersey Shore
    Just a slight haze that is only you can only see in the deep end. I would say its white. Brushing daily, was vacuuming but put the dophin in last night and will continue with that.
    Between the dolphin and a couple of days it should clear...then you'll be OK.
    White haze usually means something besides algae--or dead algae. Is your calcium high?
    Katy, TX
    I'd bump your salt level up to 3200, for the start of the season. My calculator will help you figure how much salt you'll need . It's in my sig below.
    Michael
    Jersey Shore
    CarlD, calcium is at 210
    mwsmith2, have been usiing your calc., works great and makes life alot simpler. Thank you by the way.
    Dave
  1. Help with opening up a !0,100 gal AGP
    By yardbird in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-27-2012, 10:00 PM
  2. CYA at opening
    By PBLsQuad450 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-16-2011, 09:48 PM
  3. Will I need vac for opening?
    By poolbee in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-21-2007, 02:04 PM
  4. Low pH upon opening
    By kacy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-11-2006, 10:14 AM
  5. Opening Day
    By TwistyKat in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-06-2006, 08:46 AM
