Thread: Is BBB method more economical?
    Default Re: Is BBB method more economical?
    Quote Originally Posted by fission7x View Post
    I read on this fourm somewhere that 1 pound of pool-specific granular chlorine is equal to 2 gallons of 6% bleach.
    The following table gives the equivalent values for one pound of each form of chlorine and also shows the affect in a 10,000 gallon pool (with 100 ppm TA, 30 ppm CYA and 7.5 pH initially) where the pH and TA are shown AFTER the chlorine is used up (by disinfection, oxidation, breakdown from sunlight).
    Code:
    1 pound of...
    Form of Chlorine     Equiv. 6% Bleach    FC     CYA    CH    pH      TA
    1 pound 6% Bleach       0.11 gallons    +0.7    0      0     0       0
    1 gallon 6% Bleach      1.0 gallon      +6.2    0      0     0       0
    Tri-Chlor               1.8 gallons    +11.0   +6.7    0    -0.41   -7.7
    Di-Chlor                1.1 gallons     +6.6   +6.0    0    -0.21   -2.3
    Cal-Hypo                1.3 gallons     +7.7    0     +5.5  +0.77  +11.3
    Chlorine Gas            1.9 gallons    +12.0    0      0    -0.62  -16.9
    If the chlorine you are referring to is "granular", it is more likely to be Di-Chlor as Tri-Chlor is typically in the form of solid pucks or tablets (3" or 1" in diameter). The ingredient label should say something that makes it obvious (like "...dichloro..." or "...trichloro...").
    Prices vary across the country, but it may be that chlorinating liquid from your pool store or a hardware store might be more economical for you. I am able to get 12.5% chlorinating liquid for $2.50/gallon so the price of 6% bleach would need to be less than about $1.25/gallon to be equivalent. So you may find that you can find a better deal for chlolrinating liquid than bleach in your area (and you'll carry less weight for the same amount of chlorine).
    As for using a lot of chlorine because of the size of your pool, that is very true though having a pool cover will help cut down consumption considerably. Because of my electric pool cover, I only use about 0.5 ppm or less of chlorine per day so that's about 1 cup of 12.5% chlorinating liquid per day in my 16,000 gallon pool. Of course an SWCG system is the easiest method of generating chlorine of all (and like liquid chlorine, has no CYA nor CH increase and is fairly neutral in pH though most users see a pH rise possibly due to carbon dioxide outgassing from the aerating hydrogen bubbles that are produced by the SWCG). Another way to reduce chlorine consumption is to add Borax to your pool to get to 50 ppm Boron content (see this thread for more info on how Borax reduced chlorine consumption by acting as an algicide so that chlorine didn't have to).
    Richard
    I find having to drain half my water and refilling to lower CYA from too many pucks to be VERY un-economical.
    Then you have to toss in the cost of all those boxes of Borax you need because the pucks make your pool too acid.
    Then you have to buy tons of bleach or liquid chlorine anyway because the pucks raised the CYA so high that you couldn't use them to raise the FC high enough to compensate and now you have a big, fat algae bloom and you're going to have gallons and gallons of bleach every day to kill it.
    But if you dilute 12.5% LC half and half with fresh water you may be getting 6% at a lower per gallon cost than even in the grocery stores. Nothing wrong with saving a few bucks! Why bother? Because at 12.5% LC is highly unstable and will break down into lower concentrations and you'll lose the edge. But if you dilute it yourself, you'll have 6% and that's got a lot longer shelf life--but you'll still want to keep it shaded and cool.
  1. BBB method
    By CarterCrew in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-21-2012, 10:19 PM
  2. help with bbb method
    By clayboy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-20-2012, 04:46 PM
  3. Are Salt Generators more economical than bleach over the lifetime of the pool?
    By cnk in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 02-28-2007, 12:27 AM
  4. What is the BBB method exactly?
    By sdmanship in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-28-2006, 02:41 PM
  5. BBB Method
    By fritochiprt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-15-2006, 05:46 PM
