Thread: pool deck
    Dec 2005
    Default pool deck
    hi have a 15x30 ew pool and planning to build a deck.I was trying to descide
    what to use for the decking.i have a composite deck that the pool deck will
    attach to. the composite deck get so hot you can walk on it with bare feet.
    i was thinking of using marine plywood and covering it with indoor outdoor
    carpet like the stuff used on aluminum decks.does anyone have any pros or cons about using the marine plywood and indoor outdoor carpet.
    thanks.
    Default Re: pool deck
    Hi, the deck in this photo was sealed and then carpeted with indoor, outdoor. It has been three years now and still in very good condition. Pay a little extra for a good grade of carpet and you should be fine.
    http://www.shadebuilder.com/poolshade.html
    Marine plywood - even though the name implies water, is not really a great product to be lying flat and collecting water - no wood is - I don't care how well you seal it - marine plywood does well if it's upright and allows for moisture to drain down the face.
    I would recommend doing the deck in composite, there are several types, all with advantages and disadvantages, from research for doing my deck, I found it best if you buy a composite with 49% wood fiber, a light finish and rough surface, it will be comparable to wood WRT heat. If you buy composite that contains a higher percentage plastic or vinyl (worse) and has a smooth finish you will get more heat.
    Finish has a lot to do with the heat transfer to your skin.
  1. Brass deck jets versus Jandy deck jets
    By pumpkineater59 in forum Pool Equipment & Operations
    Last Post: 04-13-2012, 12:58 AM
  2. in deck or on deck slide and diving board
    By bszaronos in forum Pool Equipment & Operations
    Last Post: 03-16-2012, 12:52 AM
  3. moss on a carpet covered deck (factory pool deck)
    By JETTA in forum Above-Ground Pool Construction & Repair
    Last Post: 09-08-2006, 08:56 PM
  4. ag pool deck
    By kanane in forum Above-Ground Pool Construction & Repair
    Last Post: 05-25-2006, 10:44 PM
  5. Pool deck
    By Denfel in forum In-Ground Pool Construction and Repair
    Last Post: 04-12-2006, 10:09 PM
