Closed Thread
Results 1 to 9 of 9
Thread: Algaecide
    .Joppa, Maryland
    Default Algaecide
    How much algaecide should I add to 18,000 galon IG vinyl for winter? I live in Harford County, Maryland.
    Thanks, Marty
    duraleigh Guest
    Default Re: Algaecide
    The dosage will be on the label.
    .Joppa, Maryland
    Thanks Dave,
    I didn,t know if more would be better or if it would have any negative effects on the rest of the water chemistry.
    Marty
    duraleigh Guest
    Gotcha' now. I personally don't use it but those that do seem to indicate it's fine to overdose a little. Others better informed will give you a more accurate opinion.
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Just make sure you are using polyquat algaecide.
    CaryB
    Dec 2005
    Lakewood, CO, USA.
    Where are Ben's instructions?
    I think the standard for the Polyquat 60s was 9oz (initial treatments) -16oz (visible algae) per 10k of water - I put in 32oz today to prep for closing (the size of one bottle)
Closed Thread
  1. Use of algaecide
    By onemsmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2013, 05:33 PM
  2. algaecide
    By vinper in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-24-2013, 12:24 AM
  3. Is any Algaecide better than nothing?
    By NullQwerty in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-16-2006, 09:17 PM
  4. Can anyone tell about HTH Algaecide
    By poolboyforjenny in forum Dealing with Algae & Slime
    Last Post: 08-21-2006, 07:25 PM
  5. algaecide overdosage
    By lmheid in forum Dealing with Algae & Slime
    Last Post: 05-21-2006, 02:46 PM
