TMan
Thx TP, I have an AG but I'm plumbing it with schd. 40 anyway, and will T it in, almost finished. Another issue, I'm using a SWG too and want to plumb it in Before the solar heater, not after. This is because the model I have reduces chlorine output when the water gets warm, anything above 90-degrees for mine and the 'check cell' light starts flashing. I expect the heated return water to be well above that. Then it will not be generating at optimum meaning more run time during the evening/morning, cooling off the pool and then I'm going backwards. It'a a Goldline AquaTrol for AG pools and works well, within a range. What do you think of running the chlorinated water thru the solar heaters? I'm guessing that now it's hotter, chlorinated water being returned to the pool.
