Results 1 to 10 of 14
Thread: Please help with chlorination method
    Howell, Michigan
    Default Re: Please help with chlorination method
    I thought I read once that pouring chlorine directly into the skimmer wasn't a great idea because it subjects your pump to a low ph bath and can prematurely corrode it. Seemed to make sense, so I always pour it around the perimeter of the pool.
    Bleach has a pH of 12 or 13, I forget which......so low pH isn't going to be a problem.
    Janet's right--Bleach is high pH. Di-Chlor and Tri-Chlor are low pH.
    Still, I keep the pump running for several hours after I pour in the bleach, so thousands of gallons are flushing it anyway--that's its job. So unless you are letting the stuff sit in there with the pump off, I don't believe it's an issue.
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    If you use a inline feeder should you turn it off if pouring bleach in the skimmer?
    John
    I would just not pour the bleach into the skimmer--pour it slowly into the return stream.
    Katy, TX
    The pH of bleach is 11.
    Michael
    Bleach which is poured into the skimmer is so quickly dispersed into the pool, that it isn't a problem.
    Watermom
  1. Start up super chlorination?
    By gilbertpsk in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-24-2012, 01:21 PM
  2. Breakpoint Chlorination
    By chem geek in forum The China Shop
    Last Post: 09-20-2006, 07:53 AM
  3. How do you manage your SWG chlorination level?
    By joelq in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-29-2006, 09:23 AM
  4. cya and saltwater chlorination
    By bizbad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-24-2006, 11:24 PM
  5. Auto-Chlorination? Here might be an option.
    By keithw in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-15-2006, 12:31 PM
