Thread: two issues w/IG Vinyl, rock in shallow end and sidewalk supports
    Central New Jersey
    Default Re: two issues w/IG Vinyl, rock in shallow end and sidewalk supports
    Well I spoke to my construction guy..
    The cover 6" PVC tubes will be replaced by the concrete guy by post hole digger and setting new tube in hole...
    Id like to be there to see it! But I intend to borrow a vibrating compactor and just do in and around everything (trying to stay 1' away from pool). In addition, He said the soil should be packed under steps but hasnt, and he still to state who is to do that?? Ill call again.
    The rock in the pool issue - he says its a remanant piece of the bottom matl. and will be flattened out by a rubber mallet ( I think Ill have his guy do this or should I -it is my liner and this guy may just whack it untill its done or ripped)
    Thanks for the responce and all the help this site brings
    Cool Re: two issues w/IG Vinyl, rock in shallow end and sidewalk supports
    Digger, any and all fixes are the builders' responsibility when the pool is new and untouched. If you have any trouble with it, please let me know. I wouldnt use the compactor until the original 'tubes' are found - they'll do better if set into the collar and coupled onto. Just my $.03
    Central New Jersey
    That sounds good, Ill leave the liner rock alone, he'll address that today
    As far as settlement goes I already ran the small compactor in and around the pool, dug out two piles which were visable- looks much better and I agree the piles going down to the collar are worth digging up.(concrete sub is to perform this) cant find any plans depicting the placment or number of piles....
    I pushed soil under my steps twice, thats looking much better
    Concrete guy seems anxious and he stated it should take him 1-2 days, which sounds great. Because we want to do some paver areas/walks after this ..
    Again thanks for your input
    dont mean to be a pain, but I know concrete is going to crack. But the pool company stated they have been only doing this for 2 yrs and to me thats not much-So i come here and rant and use the compactor at night instead of listening to my wife..LOL
    Ohh and Brad I been so busy with the kids football and the POOL I havent taken any pictures as of yet.....but will after the rains this week THANKS
    and to note the tubes are 4" and approximately 3' in length set in the concrete collar of various thicknes, although it did look like quite a lot of material.
  1. Deck supports on/near buttress supports
    By bradatkins in forum Above-Ground Pool Construction & Repair
    Last Post: 08-10-2012, 10:23 PM
  2. Fanta Sea - Plastic supports to wood
    By ccullin in forum Above-Ground Pool Construction & Repair
    Last Post: 06-09-2012, 11:11 AM
  3. Help! Pool Cover Issues and Leak Issues
    By b2001 in forum Pool Equipment & Operations
    Last Post: 02-17-2008, 05:34 PM
  4. So, am I ready to ROCK???
    By Pool_Mike in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-22-2006, 10:01 AM
  5. Crooked Upright Supports
    By snorkly in forum Above-Ground Pool Construction & Repair
    Last Post: 06-22-2006, 04:24 PM
