Thread: Rain! Pool full - drain or wait?
    Mesa, AZ
    Default Re: Rain! Pool full - drain or wait?
    Usually after a really big rain, I drain water until the skimmer just starts working, then let evaporation take it from there.
    Sugar Land, Texas
    I'm curious about something.
    I see a lot of posts about draining the pool after a rainstorm.
    Are these pools not equipped with overflows, or is the overflow simply not adequate to handle the volume of rain that falls?
    Pool owner - contract signed 21Aug2006; HOA approval granted; complete - existing patio demolition; excavation; rebar; embedded plumbing; gunite; plumbing; electrical; tile and coping; decking; plaster; pool fill; acid start-up; regular start-up; pool school; gas meter upgrade; additional of salt; PDA remote programming.
    Orlando, Florida, USA.
    Quote Originally Posted by eljefe281 View Post
    I have an oveflow built into my "autofiller". It uses a one inch PVC line for the overflow drain. After a heavy night's rain if my pool is 2 inches high, it will take all day for the water level to drop.
    Scottsdale, Arizona
    I'm more concerned with water getting behind the pool walls at the coping than chemistry when mine gets flooded .. If the water is at or above the top of the tile, I backwash until it is in the center where I keep it.
    Sanford, FL
    Mine is right at the top line of the tile after about 5-6" of rain in the last week. DH and I were debating a drain - if we get another soaker today - I am draining about 2" out.
    Yes you will need to add more salt if you have to drain and your salt level is low - my pool builder says that the warning light is just that - a warning. But if you drain it the salt concentration will not increase - just add about 1/2 as much as you think you will need and then test and see if you need more.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    joliecharlie is offline ** No working email address ** Thread Analyst joliecharlie 0
    Pinehurst, North Carolina
    We are on a well so we are thankful for a good rain to fill our pool. We drain/backwash so that the skimmer works and let evaporation take over from there. If we have a big rain expected, such as tropical storm, we drain some water prior so we won't have have the problem of water behing liner. I am interested to know if we could retrofit an overflow valve to our existing pool...that would certainlly be helpful if we were out of town and couldn't manage the water.
  1. How full is full on an easy set pool?
    By Larryh86GT in forum Intex-type Pool Setup & Operations
    Last Post: 06-28-2013, 11:02 PM
  2. I have a pool full of kids!!!
    By aylad in forum General Interest
    Last Post: 05-29-2012, 11:03 PM
  3. While my pool lies in WAIT ...
    By debs_pool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-22-2006, 02:18 PM
  4. Too much rain, need to drain
    By Macrosill in forum Pool Equipment & Operations
    Last Post: 07-12-2006, 09:33 PM
  5. Pool only 1/2 full
    By newtopools in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-12-2006, 03:49 PM
