Thread: Pool PH Always High
    Default Pool PH Always High
    Since I had my pool liner replaced, over 1 year ago, the PH is always elevated when I check (not too often recently). The pool repair company said that PH woudl be high after the new liner and I should add acid to control. I did that for 3-4 months religiously and situation has stayed the same. Wouldn't the liner have stabilized by now? It always requires 3-drops of neutralizer to return to acceptable PH, no matter how infrequently I check the PH. Is it possible my PH is OK, and my chemicals are too old? I checked PH today and it was 8.3, and again 3-drops of neutralizer returned to acceptable. I added 1-gallon of acid to the 15k-20K gallon pool.
    I keep chlorine on high side w/ 3" tablets in a floater basket that gets continuously bathed by spa outflow. I closed the basket ports today to reduce chlorine which was higher than usual, at upper end of visual "yellow" scale.
    Default Re: Pool PH Always High
    I have never heard anyone say that a new liner would cause ph to be elevated. That's a new one. I replaced my liner this summer and didn't find that to be the case. How old is your test kit?
    It's old, but the chemicals are probably 3-5 yrs old. The tests seem to work fine but the results are puzzling. I will get some new chemicals and try them. I'm almost out of the 5-drop parts anyway.
    regards
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 05:47 PM
  2. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 11:52 PM
  3. How high is too high chlorine to enter pool?
    By vaubach in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-13-2011, 06:15 PM
  4. High Phosphates > 1,000 & High Nitrates 90ppm
    By applepar in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2011, 05:49 PM
