Results 1 to 10 of 10
Thread: FOUND cause of filter allowing dirt/bugs in pool
    Attleboro, MA.
    Default FOUND cause of filter allowing dirt/bugs in pool
    Well I broke down the filter today for winter closing. The standpipe that the laterals are screwed into isn't snug enough when the valve ***embly is installed on top of it allowing everything that's floating on the top of the water to go inside and right out the return into my pool! The pipe and valve ***embly is scratched and also there was a ton of bugs, etc in that area.
    Now how to fix that? Matt 4X4 had a great idea of using electrical tape around the standpipe however that will only last 1 season. Not a big deal to replace every season when it's broken down. Any other suggestions out there?
    Nicole: 18' round AG with AstralPool Sand Filter and 1.5hp AstralPool Pump
    Default Re: FOUND cause of filter allowing dirt/bugs in pool
    could try silicone?
    Attleboro, MA.
    Would I put the silicone on the standpipe or inside the valve a$$embly? Also wouldn't that also be something I would have to replace annualy?
    Honesdale PA
    Don't be too sure about the electrical tape lasting only one season. Advantage of the tape it's a slip fit whereas silicone isn't. You can also control the thickness of the seal with the number of layers of tape you use. If it's similar to my Hayward, you don't want to seal that joint completely as I think that is an air bleed path from the top of the chamber.
    Attleboro, MA.
    I actually have another little tiny pipe that runs along the standpipe and I would guess that would be for air. It has a little white cover on top with slats to allow air/water in and out but so that sand/debris can't enter into it.
    Attleboro, MA.
    Here is a picture of it. You can see that tiny tube with the white cap. Hopefully that is for air because I intend to do my best alleviating that gap between the valve a$$embly and standpipe. I'll try the electrical tape method.
    Honesdale PA
    Mine doesn't have that tube. Any way to tell if it's plugged?
  1. AZkid - Hayward Sp 711 filter pours dirt back into pool
    By AZkid in forum In-Ground Pool Construction and Repair
    Last Post: 05-16-2011, 06:28 PM
  2. DE filter letting bugs through
    By willdozen in forum Pool Equipment & Operations
    Last Post: 06-30-2010, 09:26 PM
  3. Sand filter allowing bugs to enter pool
    By nicole12 in forum Above-Ground Pool Construction & Repair
    Last Post: 09-05-2006, 10:50 AM
