Thread: One more moron question
    tagprod is offline ** No working email address ** tagprod 0
    Default One more moron question
    Man I feel like an idiot not being able to figure some of this out
    I have a Hayward 2HP pump and a 1.5 HP pump for the water feature. The 1.5 pump came with a tool used to pull the top off to access the strainer basket. The 2HP pump did not. I'm not sure how to get the top off - I tried beer j/k
    Anyway there is a clear top that sits on top of a black cap or housing. Is it just the clear top that comes off? Before I charge in there with a m***ive dose of brute strength I wanted some re***urance on what I'm actually supposed to do.
    duraleigh Guest
    Default Re: One more moron question
    I ***ume (okay, you non-thinking WATCHDOG, I'LL SPELL IT SO IT'LL POST ANYWAY!!!)a-s-s-u-m-e (Gotcha! )you're talking about the strainer basket lid. Both lids on both pumps should have a couple of ears that allow you to bump the lid with the palm of your hand about a 1/4 turn counterclockwise. You can then lift the lid off. (you may have to pull pretty good to break the vacuum after the 1/4 turn)
    Neither pump should require a tool to get the lid off.
    the tool I'm talking about came with the smaller pump (made by Hayward) and fits perfectly on the top.
  1. Spring Vacuum Question and Liner Question
    By DougM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2011, 12:11 AM
  2. Okay I feel like a total moron asking this but...
    By scootchu in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-26-2006, 05:58 PM
