Thread: TIP: Black Algae Removal
    Steve #1 is offline ** No working email address ** Steve #1 0
    Thumbs up TIP: Black Algae Removal
    OK, so I had a bit of a black algae problem.
    So after reading through the forum here I found that the best way to deal with it was to rub a thrichlor(sp?) puck in to it. So I give it a try and it worked pretty well on what I could reach from the deck. The problem was getting the deeper part while holding breath underwater and trying to rub while not pushing away from the wall. My first thought was to fill the SCUBA tank and attack it that way..... then I had a redneck revelation.... I needed a puck on a stick.
    OK, since I said redneck, and if you read the thread on my "trash bag method" you know Duct Tape will be involved. The problem is, you can't just tape the puck to a stick. Brace yourself for the brilliant part here.... what you do is take a clamp put the puck in the clamp and tape the clamp to the stick.
    Now for puck on a stick:
    It worked pretty good. The puck stayed in the clamp and I had a ton of leverage to rub it in to the wall.
    BTW: The pics will probably be gone sometime tomorrow as I'm changing ISPs. The guy should be here any minuet to install the fiber optic..... I'm not a complete redneck
    Jul 2006
    Nova Scotia CANADA
    Default Re: TIP: Black Algae Removal
    LOL,
    okay that was pretty good inventing
    Hope the algae dissapears quickly for you, Best of Luck!
    catnip is offline Registered+ Thread Analyst catnip 0
    Blue Mountain Beach, FL
    I've had good luck with the direct application of tri-chlor to black algae spots, but I agree, this beats the hold your breath / scuba tank method for convenience!
    Chuck
    16,000 gallon gunite/plaster, Pool Pilot Digital SC-60, Pentair UltraFlow 1 HP pump, Pentair Tagelus TA 60 filter, Polaris 280
  1. trying to get rid of black algae
    By tulsapool in forum Dealing with Algae & Slime
    Last Post: 06-25-2013, 12:45 PM
  2. New member-Algae stain removal tips?
    By DC912 in forum Dealing with Algae & Slime
    Last Post: 08-28-2012, 10:24 AM
  3. Black Algae??
    By cmack in forum Dealing with Algae & Slime
    Last Post: 09-09-2008, 02:37 PM
  4. Black Algae - what does it really look like?
    By jhm in forum Dealing with Algae & Slime
    Last Post: 07-05-2006, 12:34 PM
