Results 1 to 3 of 3
Thread: Crunch time
    Bowling Green, Kentucky
    Default Crunch time
    For me, anyway.
    Opened pool today, here are my numbers:
    Ph 7.7
    Alkalinity 120
    Cl 2.5
    CYA 40 (this is guess; don't have Ben's test kit yet; out of reagent to test for it)
    Water pretty clear. I have a solid cover so that obviously helps.
    My thought is to lower alkalinity a bit, maybe to around 100. Like to keep Ph at 7.3-7.5 range, as I've had algae in the past and want the insurance of chlorine being effective. Also, I have some poly 60 to add in. Should I add a whole quart to start or just a weekly dosage?
    What should I do first, adjust alkalinity? Add bleach? Poly? Don't want to misstep early. A little nervous about screwing something up.
    Pool is 30,000 gallon, vinyl liner.
    Advice will be appreciated.
    Katy, TX
    Default Re: Crunch time
    Don't worry about the alkalinity. It will drop when you adjust your pH. I'd say adjust pH, bump your Cl up to 4 or 5 and you're all set. No need for the poly.
    Michael
    Thanks for the help.
  1. Long Time Lurker, First Time Poster
    By MikeD in forum Dealing with Algae & Slime
    Last Post: 08-04-2012, 08:26 AM
  2. still have ben's kit, time for new kit?
    By vinouspleasure in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-03-2012, 08:06 PM
  3. Long time reader, first time author
    By j_stewart89 in forum General Interest
    Last Post: 04-06-2012, 06:05 PM
  4. Maybe it's time
    By bizzelizze in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-14-2010, 08:28 AM
  5. Help! Big Time!
    By PoolKid in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-20-2006, 10:34 AM
