Closed Thread
Results 11 to 12 of 12
Thread: How Do I Winterize My Sand Filter?
    Carterville,IL
    Default Re: How Do I Winterize My Sand Filter?
    not to do with winterizing, but is it true that when you move the lever to filter, backwash, rinse etc should you always be rotating it in the same direction.....such as clockwise or counter? I heard you should choose a direction and stick with it????
    Sorry to dent the subject, but was reading up on "winterizing" learning as well, and thought of this ?
    It shouldn't matter which way you turn the handle, however a bunch of 'pool pros' say to do it only one direction.(I was taught this at the same time I was taught to only use 'pool store chems' and that bleach is bad for a pool ) A properly lubed and maintained multiport doesn't need that. I think what they're trying to avoid is the 'spider' or 'wagon wheel' gasket unseating or tearing. I've found this to be a 'non issue' as long as the multiport is properly cared for.
Closed Thread
  1. Best Way to Winterize Filter/Valve
    By bordersong67 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-20-2012, 01:48 PM
  2. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 08:36 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
    Last Post: 05-30-2007, 11:01 PM
  4. How Do I Winterize My Sand Filter?
    By bsbrega in forum Above-Ground Pool Construction & Repair
    Last Post: 09-02-2006, 03:21 PM
  5. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 12:01 PM
