Thread: Heat Pump comparrison
    Jul 2006
    Default Heat Pump comparison
    We are building a new pool. We have our choice between a Hayward heat pump http://www.inyopools.com/Products/02200001004952.htm or a Pentair Heat pump.http://www.inyopools.com/Products/03500014029312.htm Anyone have any opinions on which is better???
    Ft Lauderdale, Fl
    Default Re: Heat Pump comparison
    Jinx,
    When comparing Heat Pumps, you want to look at the COP ratings for equivalent BTU outputs. The COP = Coefficiency of Performance is similar to an Air Conditioners SEER rating. A value of 5.0 is considered good for Heat Pumps. So 5.5 - 6.0 are even better. Greater than 6.0 are super efficient systems.
    Also look for Titanium Heat Exchangers, which adds protection to the heat exchanger from water chemistry damage. Cupero-Nickle Heat exchangers will leach copper into the water and will create a higher potential for metal staining.
    Finally, consider the ability of the heat pump to operate when the air temperatures fall below 60 degrees. This can create a freezing condition for the condensation water within the heat pump and shut down your heater. Most manufactures offer a defrost cycle that allows the heat pump to continue operating well below air temps that you would want to consider stepping out into (30's).
    Another one to consider (if your builder will accept your suggestion) is the largest and one of the oldest heat pump manufacturers, www.aquacal.com.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
  1. which heat pump would be best? what should I look for?
    By alisonquilts in forum Pool Equipment & Operations
    Last Post: 08-23-2012, 07:28 PM
  2. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
  3. What heat pump NOT to buy?
    By marcs in forum Pool Equipment & Operations
    Last Post: 01-28-2007, 04:18 AM
  4. Heat Pump
    By mohawk in forum Pool Equipment & Operations
    Last Post: 09-04-2006, 12:08 AM
  5. Exactly what is a heat pump?
    By JETTA in forum Pool Equipment & Operations
    Last Post: 06-26-2006, 01:32 AM
