Closed Thread
Results 1 to 9 of 9
Thread: good pool design
    South Florida
    Smile Re: good pool design
    Good point about the skimmers... I forgot to mention that.
    About the 1-1/2" directionals.... One of my customers made a mistake and stubbed 2" through the wall. I went on a search for a 2" fitting and could not find one. If any one knows if such a thing is out there, please let me know.
    And please forgive all the typos in my posts. I'm using a lap top and those long fingernails.......
    Zina
    Pool-Design . net
    Default Re: good pool design
    Very interesting!
    Setting up stub-outs should be a no-brainer for the installer since they are working with PVC. They can be capped out with a glued-on cap that gets sawed off, or a screw end with either a screw in plug or a screw on cap, depending on whether it's a F or M fitting. PVC is SO easy to work it doesn't matter which.
    They shouldn't charge you much for setting up for a future heater--just for the extra fittings and maybe 15 minutes labor--if they do it as they run the lines.
    If you are having electrical setup done, have the electrician run the lines for the future heater as well. Even if all he does is pull the wire and leave it near the box in the house, it will help. I had my electrician run 220v 40amp cable. He ran it from the box to just inside the wall near where a heater would go. If I ever put in a heater, it will be a heatpump and the wiring is ready to go.
    Lenny is offline Lifetime Member Thread Analyst Lenny 0
    Wilmington, Delaware
    I was thinking about starting a new thread for this question but it's info that might make sense in this thread.
    I have a PVC pipe that appears to be some kind of by-pass. It runs from the inlet piping (just above the ground on the piping leading to the pump. It's connected to a T on the main drain pipe) to the outlet side (where it has it's own shutoff valve). I have left the valve closed because I'm not sure what it's for.
    Any ideas?
    Thanks.
Closed Thread
  1. Help me design a ramp?
    By AnnaK in forum Pools, Pets and Creepy Critters
    Last Post: 01-02-2007, 05:40 PM
  2. Pool Design Consultant
    By gordonhyde in forum In-Ground Pool Construction and Repair
    Last Post: 09-06-2006, 11:12 AM
  3. Pool Design Consultant
    By gordonhyde in forum Pool Equipment & Operations
    Last Post: 09-05-2006, 05:12 PM
  4. pool plumbing and design
    By us7sail in forum In-Ground Pool Construction and Repair
    Last Post: 06-15-2006, 01:57 PM
  5. Decorative rocks / design around the pool
    By slowtan in forum Above-Ground Pool Construction & Repair
    Last Post: 04-26-2006, 01:57 AM
