I have used both sequasol and metal free. They are both good, so it doesn't matter which you use. I would add a good dose right after your fill - a little more than the bottle says. You will not have to do anything else when you close. I have already closed with stains and opened to a stain free pool - I don't know why, I can only guess, so don't worry about adding any sequesterer when you close. I would save the chemicals for next year when you open. Next year when you open, before putting anything else in the water add the sequesterer. This way any metals the were introduced over the winter or with your fill water will be taken care of. Then you only need to add it if you see any stain starting to form. If you see stain start, take your ph down to 7 - 7.2 and add sequesterer - it should lift the stains before they settle. Feel free to ask any questions you have![]()
Do you have to fight low pH too?
It may be because it has been dry and I haven't used many trichlor pucks this year. I used to use them to keep the ph low so I wouldn't get stains. This year I didn't have any problem with stains so I have been just using bleach. I didn't check it today, but it probably is low from all the rain. What town are you from?
You should be ok with the sequesterer. Don't worry so much, I know it's a pain, but you will get the hang of it. If stains do start to come back, just lower the ph and add more sequesterer - it will fade the new stains right away. It is just the embedded ones that need the ascorbic acid. My water temp is 68 too
