Thread: How much Muriatic Acid?
    mas985's Avatar
    Pleasanton, CA
    Default Re: How much Muriatic Acid?
    I think bleachCalc (PH menu) uses the following formula:
    Pool Volume (gallons) * .0008 = oz of acid for .2 PH down.
    Another rule of thumb is that you should not put in more than a pint per 10000 gallons at one time.
    Mark
    The actual amount of Muriatic Acid you need to add to get a desired change in pH is dependent on the starting and ending pH as well as the TA level. The formula given in the previous post works correctly going from 7.7 to 7.5 with a TA of 110. Therefore, the advice of adding less than the calculated amount and seeing the effect before adding more is good.
    If I can figure out how to simplify the formulas that account for starting/ending pH and current TA, I'll update Michael Smith (the creator of BleachCalc) with some new formulas that will be more general. I have a spreadsheet that calculates all this stuff, but it is way too complicated for general use (though I'm working on simplifying it).
    Richard
    mccato is offline ** No working email address ** mccato 0
    Ga
    Thanks everyone!
  1. Can anyone tell me where to buy muriatic acid?
    By blessedbeingmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-06-2011, 02:35 PM
  2. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  3. How to add muriatic acid
    By BullDean in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-12-2006, 11:51 PM
  4. how much muriatic acid
    By wolfcue in forum Dealing with Alkalinity and Calcium
    Last Post: 06-07-2006, 06:55 PM
  5. How much muriatic acid to add?
    By Blemished_Chemist in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-04-2006, 09:15 AM
