Thread: What salt to add to poolfor swg?
    fjava Guest
    Default What salt to add to poolfor swg?
    Can I use "Cargill Salt
    40 Pound Salt Pellets Water Softener" from lowes?
    http://www.lowes.com/lowes/lkn?actio...5654-113-25654
    Saint Cloud, FL
    Default Re: What salt to add to poolfor swg?
    Yes. It has greater than 99.5% purity
    Pat
    fjava Guest
    Thanks PatL34,
    But are Salt "Pellets" ok?
    Thanks..
    Tom
    Mesa, AZ
    Pellets are fine, they just take longer to dissolve. If you pile them up over the main drain and divert most of the flow through the main drain, they should dissolve quite quickly anyway.
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:58 PM
  3. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
  4. Salt in a Non-Salt Water pool
    By wollypog6 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 10:01 AM
