Results 1 to 5 of 5
Thread: Red eyes
    Smile Red eyes
    Is the red eye's people get while swimming due to the ph or the alkalinity being off? Is it too high or too low? How does it effect the eyes if it is too high or too low?
    It used to be said that it was chlorine that caused the red eye's but I read (maybe somewhere here) that that is not the case.
    I'm sure someone here can supply me with the info on how to eliminate the red eye problem(besides Visine).
    California
    Default Re: Red eyes
    Mostly if the pH is too high or too low away from around 7.5 then this can cause eye irritation and is the most likely cause. Also, water that does not have enough salt in it can be more drying and irritating to the eyes (other threads have explained this through the process of osmosis). TA, CH and CYA are unlikely to irritate the eyes with the ranges one normally finds in pools. Very high chlorine could irritate the eyes, but this is much more likely in a pool with little or no CYA (where the disinfecting chlorine level would be higher).
    If there is CC (combined chlorines), especially certain chloramines, then these can make the eyes sting.
    If you have a problem with stinging eyes, check your pH and CC levels first as a pH far away from 7.5 or a CC > 0 could be the cause.
    Richard
    Richard, PERFECT RESPONSE!
    Paul, as Richard said, those 2 things are what causes the 'burning, red eyes', if you adjust your chems to get the water within those perameters, you shouldn't have any more eye problems. Welcome to the forum, it's a pool owners best resource (esp. with folks like Richard here) for effective and less costly advice to keep the pool properly maintained!!
    California
    Quote Originally Posted by waste
    Your check will be forthcoming in the mail shortly...
    Talking Re: Red eyes
    Quote Originally Posted by chem geek View Post
    No go Richard, the last one bounced
  1. My eyes, my eyes
    By shadowman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-09-2008, 07:57 PM
  2. Is it a stain, or my lying eyes?
    By steveinaz in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-23-2007, 08:56 PM
  3. Does perfect CL levels mean no irritation to eyes?
    By rastoma in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-19-2006, 09:41 AM
  4. Bad taste in water and burning eyes
    By Gizmobyte in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-06-2006, 10:03 PM
  5. Chlorine-red eyes
    By Palmer in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-24-2006, 04:15 PM
