Closed Thread
Results 1 to 10 of 12
Thread: Solid Loop-Loc. With or without center mesh
    Default Solid Loop-Loc. With or without center mesh
    I am looking to purchase a solid Loop-Loc cover. Cannot decide whether to get the one with the center mesh panel or totaly solid. Either way it seems like you would have to drain water either from top of cover or from pool.
    Renee C is offline ** No working email address ** Renee C 0
    Jul 2006
    Default Re: Solid Loop-Loc. With or without center mesh
    I have the same questions. We are looking for recommendations for a good winter cover. We are planning on a loop loc, but are unsure which way to go. Please help.
    Renee C
    I too have the same question. I'm going loop-lockbut not sure of center mesh or solid type. Is it true that either way have to drain water from the top?? Thanks for any insight.
    Michigan
    We installed a mesh loop loc last year. Since we get so much snow here, we opted against the solid one. I know they show an elephant standing on it but we didn't want the worry. Plus we wanted it clean and dry in the spring, which it was. But if we'd have gotten the solid one it would have been the one with the center mesh panel.
    Why BBB? Because money can't buy happiness, but saving it sure can!
    Jul 2006
    Thanks for the info. I think we are going with the mesh as well.
    • 28,000 gal IG
    • 45x25 Gunite Freeform
    • Pentair Wisperflow 2hp pump
    • Hayward Heat Pump
    • Stone Waterfall
    • SWG
    Honesdale PA
    I have a mesh loop-lock. Gave up on it a few seasons ago. Here in Northeast PA the continuous snow, melt, freeze, snow etc, would weight the thing down so in the late Winter it would be fully frozen in the ice block that is the upper levels of my IG pool. BAH !! My particular situation doesn't require a cover so now I leave the pool uncovered. Not knocking Loop-lock. They are good. Don't have elephants here but I do have other big critters, but the fence keeps them away from the pool.
    I was leaning toward solid or solid with center mesh vent because I was led to believe solid kept pool cleaner over winter than mesh which made for a much easier startup for following season (no green water) . Can you confirm? Also is a pump required to drain water during winter storms with a center mesh vent? thanks in advance for any insight.
    Michigan
    I thought I read that you'll need a small pump on both the totally solid ones and also the solid with mesh center. You can find that out by surfing a few sites that sell them. It's been a while since I was looking, so I could be wrong on that.
    As far as the solid ones keeping the water cleaner than the mesh, I'm sure that's true to a certain extent. But what we learned on our research when we were comparing the two, was that people that bought the solid ones still complained of having a slimey mess on top of the cover that had to be drained and cleaned off in the spring. That's exactly what we wanted to get away from. So we went with the mesh.
    If you are considering the mesh, get some sort of black blanket to lay on top of the water. That will keep the sun from hitting the water. Waterwarehouse sells basic sizes here Or search google for Keeper Klean. That's another name for them.
    We did end up green water anyway though. Let me explain why. I had ordered my black cover early in the spring and didn't get it out until the day we needed to lay it on the water during closing. I was very annoyed to find that it was cut crooked on one end and it didn't totally cover the water. It was short by 2' on one end. Also, we opened the pool later than normal in the spring, so the algae was allowed to sit there and thrive. Then when we finally did open it, the filter wasn't working properly. So our big green mess wasn't necessarily because of the mesh cover. It was because of the other things. Even so, I'm sure if I would have found this forum earlier, and simply used bleach, I would have had it cleared up in no time. It would have also helped to peel a couple corners back and add some polyquat in late April or early May, but I didn't think to do that. I will next year.
    I'm not trying to talk you into the mesh one, I'm just trying to give a little insight and advice in case you do go that way.
    Yardley, PA
    Just my small two cents. Have a mesh loop loc for the last 4 years. Here in PA we get around 12" - 16" of water during the winter (rain and snow melt). Yes I do have some ice that forms above the cover, and it can drag it pretty low, but if an elephant can make it, so can the ice.
    One benefit of the mesh cover is the addition of new water. I practically turn over 1/4 of the pool water each year this way, good method to reduce CYA and mineral build up. Lowered my CYA from above 400 to 40 in 4 years. Water is also expensive here, so not having to add 3 or 4 thousand gallons to raise the water level at opening is also a plus (saves over $100).
    I'm not cheap, but I find the mesh cover to be a suitable balance. Yes sometimes there is green algea, nothing that $10 in bleach wont cure.
    Rock Tavern, NY
    We originally did the solid tarp w/ water bags. Time consuming, but always a clean pool in the spring. Then we went with a mesh LoopLoc. Piece of cake to install, but every spring there was a green sludgey mess waiting for us. We got a solid with mesh panel PlastiMayd 2 years ago. Weighs a TON - not a 1 person job. But, the only patch of sediment is directly under the mesh panel. The water drains into it in the spring. I have read that there are much tighter mesh weaves available now that still allow water through but limit the light and sediment allowed in. They are probably midway between the traditional mesh and solid in their ease of use and performance.
Closed Thread
  1. Opened for first time with old loop loc mesh cover green swamp
    By Gretzky99 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2013, 10:01 AM
  2. Need a Safety Cover, are the new Mesh as good as solid?
    By Cold Drink in forum Pool Equipment & Operations
    Last Post: 09-06-2010, 09:56 AM
  3. winter safty covers(solid or mesh)?
    By freddyttt in forum Pool Equipment & Operations
    Last Post: 05-18-2008, 11:42 PM
  4. Overlap Liner Off-Center
    By cdognight in forum Above-Ground Pool Construction & Repair
    Last Post: 07-31-2006, 12:43 AM
  5. How to store mesh loop-loc cover?
    By MykeSS in forum Pool Equipment & Operations
    Last Post: 05-10-2006, 09:02 AM
