Results 1 to 1 of 1
Thread: My suction side leak Saga
    Broken Arrow OK
    Default Advice on skimmer leak sealant
    So I dug up lines and replaced pipe, and still had puddles of water back by my pump(in the bottom of my 3 ft. hole). I can now see that I have a cracked elbow comming out of the bottom of my skimmer. I honestly thought it was a leaf the first time I looked in there.
    So, there's no way I got 2K to drop for someone to cut up my concrete and replace it all. Is there a particular kind of putty/selant I may be able to use to fill this gap? The crack must be 1/8 in down there. I'm a little concerned that I can't see all of the crack, is there something I can use that will flow?
    27K IG Gunite
    1.5 hp pentair whisperflo
    Hayward Micron DE filter
  1. Suction side leak . . . Found in Pump Drain Plugs
    By TomC in forum Pool Equipment & Operations
    Last Post: 06-15-2012, 05:26 PM
  2. Possible Suction side leak - booster pump
    By izzicat in forum Pool Equipment & Operations
    Last Post: 06-07-2011, 02:16 PM
  3. Suction Side Air and leak
    By lcrooks in forum In-Ground Pool Construction and Repair
    Last Post: 05-13-2007, 12:02 AM
  4. Suction side leak (PIC) am I close???
    By lmnharris in forum Pool Equipment & Operations
    Last Post: 08-15-2006, 04:49 PM
  5. suction-side cleaner or pressure-side
    By JShilling in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-08-2006, 08:58 PM
