Closed Thread
Thread: acid wash for kool-deck
    Default acid wash for kool-deck
    We had a new IGP built about 4 months old. When construction was totally complete they "acid washed" the kool-deck surface and it looked great. We get a lot of algae and dirt (deck is not sealer) and I would like to acid wash it occasionally to make it look fresh. I know it removes the top surface of concrete and not something I can do all the time but what concentration and application hints? Beside the obvious protection to myself from acid solution.
    Mike
    Pool newbe
    12k IG . Marcite
    Cart. Filter
    Spillover Spa
    Lp Heater
    West Palm Beach, FL
    Default Re: acid wash for kool-deck
    Skip the acid. Pressure cleaner or a stiff brush on a handle, scrub with straight bleach, and then hose off. The acid is just going to etch the deck, after a few times that nice deck will not look so nice.
    Northern Kentucky
    My husband says his when his parents had a pool, his Mom used to go out every morning with a broom, dip it in the pool, and sweep the decking with the water. The chlorinated water kept the deck algea-free!
    Much cheaper than acid OR pressure washing, though a bit more work daily...
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    That is a great idea....we have the largest issue where we have a low spot in the deck that puddles so i sweep it off nearly everyday.(Florida rainy season rains every afternoon) so it will be easy to dip broom in pool afterwards.
    Mike
    Pool newbe
    12k IG . Marcite
    Cart. Filter
    Spillover Spa
    Lp Heater
Closed Thread
  1. Kool Deck restoration options
    By gary_az in forum In-Ground Pool Construction and Repair
    Last Post: 02-08-2017, 07:49 PM
  2. Acid Wash
    By txhomebrew in forum In-Ground Pool Construction and Repair
    Last Post: 03-19-2009, 11:52 AM
  3. Kool-Deck with Algae Problem..will stain/sealer help
    By mneal in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2007, 06:43 AM
  4. Does Kool-Deck need to be sealed periodically?
    By rbonin in forum In-Ground Pool Construction and Repair
    Last Post: 06-04-2006, 11:02 PM
  5. New Kool Deck got wet..now spotted
    Last Post: 05-23-2006, 02:53 PM
