I got a quote from one and talked with the rep. A couple of issues resulted in the discussion.
First, it was only slightly cheaper then roof top solar.
Second, having water in the attic is not very appealing despite all of the assurances. What if it did spring a leak. A simple pan to catch the water is not enough given the pressure the water is under.
Third, the rep told me that it was not as efficient with tile roofs since the attic does not get as hot. He only recommends them with composite roofs.
So I went with roof top solar.
