Closed Thread
Thread: Quick fix for leaky return line
    Default Quick fix for leaky return line
    I know this isn't proper, but I am trying to come up with a quick and cheap "band aid" for my leaking pool. It is in 1 of 2 return lines and I think I could get by with only 1 return. So I am thinking I could just fill up the line with something like a foam noodle to block the water and the leak. Any ideas or suggestions?
    I am new to pool ownership so take it easy on me por favor!
    Default Re: Quick fix for leaky return line
    AG or IG?
    I wouldn't push anything into a line because the water pressure may push it further, then it's permanently blocked....
    What about adding a valve - that's relatively quick....
    It splits somewhere underground, don't know where. If I put something in, it would be pushed to the insertion point.
Closed Thread
  1. Leaky Return
    By bradatkins in forum Above-Ground Pool Construction & Repair
    Last Post: 08-27-2012, 04:34 PM
  2. Is one return line enough?
    By McDug in forum In-Ground Pool Construction and Repair
    Last Post: 06-20-2012, 12:45 AM
  3. Air in filter/return line
    By scsteven in forum Above-Ground Pool Construction & Repair
    Last Post: 07-08-2006, 09:48 PM
  4. Polaris 360 - Leaky line connections
    By medfordman in forum Pool Equipment & Operations
    Last Post: 06-01-2006, 01:43 PM
  5. Return line
    By crosso in forum In-Ground Pool Construction and Repair
    Last Post: 05-08-2006, 10:24 AM
