Thread: Hayward Multi Valve Gasket
    Jul 2006
    Default Hayward Multi Valve Gasket
    This might be a dumb question....
    my gasket is flat and smooth on one side and rounded off on the other side.
    which side do I need to put in the grooves of the multi-valve?
    (it is a Hayward SP-740DE...if that helps)
    Honesdale PA
    Default Re: Hayward Multi Valve Gasket
    Not familiar with that specific valve but the flat side goes in the channels if it follows the convention of other valves. If you look at the channels closely you'll see they should be squared off. Curious how you're attaching it.
    BTW: No question is stupid. Always better to ask than make a 'stupid' and sometimes costly mistake.
  1. Question about replacing spider gasket on multi-port ?
    By zooba72 in forum Pool Equipment & Operations
    Last Post: 05-11-2013, 12:48 AM
  2. Hayward Multi Port Valve for Sand Filtration
    By rondun in forum Pool Equipment & Operations
    Last Post: 05-22-2012, 09:55 PM
  3. Multi Port Valve Gasket
    By CyberGypsE in forum Pool Equipment & Operations
    Last Post: 09-06-2006, 08:33 PM
  4. Multi-Valve Problem
    By farquhar in forum Pool Equipment & Operations
    Last Post: 08-20-2006, 08:02 AM
  5. Adding a multi port valve?
    By KirstenHW in forum Pool Equipment & Operations
    Last Post: 06-02-2006, 03:50 PM
