Thread: Used Doughboy
    Default Re: Used Doughboy
    Hi Scott, A doughboy is one of the easiest pools to convert to a different size because so many of the parts are the same through all sizes. You will, however need some new bottom rails. The bottom rails are stamped on the inside of the rail. You should have S rails for the sides, four TR rails for the transition corners and the rest will be marked 18. The 18 rails are for the ends and they establish the arc for the half circle ends. These would need to be changed for rails marked 16. They are a slightly different arc but it would make a difference.
    The wall can be cut by scoring it with a razor blade and then bending it back and forth. This is a lot cleaner a cut than using tin snips. I overlapp the wall by about six inches and then run a double row of nuts and bolts to hold it together. This has worked well for me.
    Best of luck, Dennis
    Thanks Dennis, That was how i thought i would do it but i wanted to make sure it would hold. Thanks for confirming that. How far should i space the bolts on the vertical? And does the dealer sell the 16' bottom tracks by them selfs? Thanks for helping me out, i just started reading this forum a few days ago and i can see your a big help to many. I'am sure i will be back with more ??s. Scott
    Hi Scott, I go about an inch and a half apart with the bolts. A dealer should be able to get the parts for you.
    Later, Dennis
  1. Second summer with our Doughboy
    By laurenfitz in forum General Interest
    Last Post: 06-13-2013, 10:06 PM
  2. Doughboy buried AGP
    By gemilina in forum Above-Ground Pool Construction & Repair
    Last Post: 04-20-2012, 12:21 AM
  3. New liner for a 28' Doughboy
    By jrh1010 in forum Above-Ground Pool Construction & Repair
    Last Post: 03-30-2012, 01:27 PM
  4. used doughboy above ground
    By traceyb in forum Above-Ground Pool Construction & Repair
    Last Post: 04-04-2006, 10:48 PM
