I agree with Simmon99 - you neet to take your chlorine higher, you may not be getting to breakpoint yet - so I would take it to 25ppms and be very consistant - everytime it goes below 25 hit it again with more chorine to get it back. This way it will kill all of the algae, you need to have all the algae dead before you use floc - then if the dead algae isn't clearing fast enough you can use floc, let it stand overnight then vacuum to waste. Be sure to brush the sides and backwash the filter while you are killing the algae, leaving the filter running 24/7.
