Closed Thread
Results 1 to 10 of 14
Thread: Hose popping off
    Massachusetts
    Default Hose popping off
    So happy to have found this wonderful forum.
    I have a new (since June) above ground pool. This morning found a hole in the hose that connects my filter to the chlorine dispenser. Pool had drained to below skimmer and don't know how long pump was running dry.
    I purchased a new hose (of course it's not the same one that came with the pool, but a replacement hose), filled the pool and tried starting up the system again. However, the hose keeps blowing off the fitting to the chlorine dispenser. I can see the pressure building in the hose and then it pops off the dispenser.
    Called the pool store who said to soak the hose in hot water so it fits further on the fitting. It fits in the same spot as the former hose.
    I just cleaned the pump, filter cartridge, checked chlorine yesterday. Could I have done something to cause pressure to be building up somewhere? Before the hose pops off I do notice that water is coming out of the return into the pool (but didn't get to check how strong before the hose flies off).
    Thank you.
    Default Re: Hose popping off
    Sounds like they sold you the cheap hose and connectors with the pool, try tigerflex and barbed connectors. Besides that, maybe 2 clamps instead of 1.
    Jul 2006
    Nova Scotia CANADA
    I agree with Matt, you may need better clamps for this new hose
    Massachusetts
    Thank you both, so much, for your prompt replies.
    I was just out looking things over and seems my husband (of course I'll blame it on my husband) put the prevail chlorine pack in the dispenser backward. I think that is causing the pressure. The pack also seems a bit "pinched". I'm going to replace the pack.
    In the meantime, the hose is not popping off, but really expands big time. I am hoping that is normal, as my previous hose did not do this. This one seems a bit more flexible.
    I know it's a stupid question..... but should the hose expand once I turn the sytem back on.
    I've never seen a hose "expand" before, on my pool, they just look like they "stiffen up" some with a bit of movement, but then they equalize and settle and look the same as always. I'm not familiar with the Chlorine pack you're describing since I only use bleach, so I really can't say whether that is part of the problem or not.
    I wouldn't trust it not to pop off again, not something you want happening when you're not around, I would look into it a bit further because it just doesn't sound right.
    Can you run without a chlorine pack and see if the problem goes away?
    A chlorinator should not give that kind of backpressure to expand a hose.
    Massachusetts
    matt:
    Actually, I did by-pass the chlorine system and go directly to the return. The hose seemed to be fine. I think I was being a bit overly concerned with the movement of the hose. It's just a bit more flexible than the original hose. I will look into the hose and clamps recommended earlier. In the meantime, I'm only running the pool when I'm around to keep an eye on it.
    I truly appreciate everyone's responses.
    i think that makes sense with own experience matt. i note that the tiger flex hose where i use it doesn't expand, but it does go sort of rigid when pressure is applied.
    Exclamation Re: Hose popping off
    If you go the 'tiger-flex' way, DON'T USE CLAMPS !!!!!!!!!!, use schedual 40 fittings and PVC primer and glue to secure them (threaded reducers with a 1 1/2" slip fitting are available at any decent hardware store). Tape whichever threaded reducers with 3 wraps (all the way up the threads) and glue the 'bell' end to the pipe. Make sure you read the instructions on the can of glue to insure a good seal. I've taken a number of 'shortcuts' in my explanation, but following this will insure a good connection. (if you've any questions about what I've advised, ask and I'll go into further detail). I beg for you to trust me on this, as I spend a lot of time every year correcting leaks caused by homeowners using tigerflex and clamps. (it's only a small % of fixes I have to do as opposed to those due to installers using 'black poly' - but that's something for the 'China Shop'. )
    T-cal, welcome to the forum, I want you to have a great 'pool experience' so am trying to prevent your doing something that will be a continual headache. Do it once, do it right and enjoy the pool.
    Carterville,IL
    Quote Originally Posted by waste
    Is there any way you could attach a photo of the correct fittings? I have silver clamps around all of my hoses that tighten w/ a screw and I DO NOT want to wake up one morning and have to refill the pool. I would love to see how your hoses are attached. Also, where would one find "tiger flex" hoses or GOOD quality hoses. I'm all about a little extra $ for a better lasting "anything".
    Quote Originally Posted by traceyb
    Tracey, I don't want to cause you any loss of sleep, the clamps work for a few (or many) years, I was only trying to say that 'if you have to make a change, and were using PVC 'flex pipe' ', glue, don't screw (as in the clamps).
    Don't be afraid of the connections you have! I only suggest that, if needed, you make the change to PVC glued connections (which are a chemical and mechanical bond) vs. a purely mechanical (the clamps) connection. It's an old saying but "if it ain't broke, DON'T FIX IT (until necessary) .
    I certainly welcome you to this forum! and hope you have nothing but trouble-free swimming! However, should you ever have any trouble, know that I and the rest of the members will 'bend over backwards' to help you!
    Fear not Brave Soul! - Waste
Closed Thread
  1. popped backwash hose near end of hose
    By Gretzky99 in forum Pool Equipment & Operations
    Last Post: 05-22-2013, 10:30 PM
  2. Pump popping breaker.
    By 737Mech in forum Pool Equipment & Operations
    Last Post: 06-14-2012, 12:38 AM
  3. Polaris 360 - Popping Wheelies?
    By medfordman in forum Pool Cleaning: Manual or Automatic
    Last Post: 10-03-2006, 12:23 PM
  4. Need Help with a hose
    By IMherDad in forum Pool Equipment & Operations
    Last Post: 07-07-2006, 08:36 AM
  5. Vinyl Liner bead keeps popping out..
    By sehicks in forum In-Ground Pool Construction and Repair
    Last Post: 04-30-2006, 09:10 PM
