Closed Thread
Thread: Skimmer plug?
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    Default Skimmer plug?
    I have two skimmers that are not threaded. Is there a plug like a gizmo for skimmers that are not threaded.
    Dave
    RavenNS is offline Established User Weir Watcher RavenNS Not to be trusted
    Jul 2006
    Nova Scotia CANADA
    Default Re: Skimmer plug?
    I think the gizmo that I saw at leslie's online wasn't threaded
    b2001 is offline Registered+ Thread Analyst b2001 0
    Dallas, Tx
    Yes - I bought one from a local pool place - rubber, so that it fits snugly into the skimmer.
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    For closing I put a plastic cover over the face of my skimmer - would I still need to put a plug in the skimmer basket? Im thinking its better for water to drain out than to stay in.
    John
    SW Missouri
    I would recommend some kind of "gizmo" in your skimmer even if you cover it from pool side. It is just a good insurance policy to have something that will take pressure if water were to leak into the skimmer somehow! I drain my skimmer completely and pour a little anti-freeze down the line (after blow out) before I put in the gizmo. Cheap insurance for what mother nature might dish out!
    I just use an empty milk jug and fill it about 1/3 of the way the weight it down. Then I put the skimmer cover back on. This works the same way as the gizmo thing.
Closed Thread
  1. Rubber plug dropped into skimmer line
    By brielly in forum Pool Equipment & Operations
    Last Post: 05-14-2012, 07:48 PM
  2. Winter plug
    By wetviking in forum Above-Ground Pool Construction & Repair
    Last Post: 05-31-2007, 01:33 PM
  3. Need to plug return and skimmer for repairs
    By jstonemo in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2007, 09:33 PM
  4. Skimmer plug got sucked through and is stuck
    By ScottsdaleSwim in forum In-Ground Pool Construction and Repair
    Last Post: 10-07-2006, 11:19 PM
  5. Do I need to remove the plug from the skimmer?
    By ValAZ in forum Pool Equipment & Operations
    Last Post: 04-01-2006, 11:58 PM
