Thread: sand filter
    Dec 2005
    Default sand filter
    hi
    I purchased a 15x30 ew pool and the pool supplier recommends a hayward
    pump and filter.my question is about the filter.the filter is round and is is not a side discharge.Is the any advatages or disatvantages with a round filter.
    Default Re: sand filter
    Hi, Hayward makes the best pool products so it should be OK. Is it at least a 1 HP pump? Does the filter have a multi port valve on the top? If so you will do just fine.
    Best of luck, Dennis
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 10:41 PM
  2. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 08:36 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
    Last Post: 05-30-2007, 11:01 PM
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 12:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 08:58 AM
