Thread: backwash position for pentair 2" slide valve?
    Default backwash position for pentair 2" slide valve?
    Hi,
    Newbie here inherited a pool with a pentair 2" slide valve hooked up to a nautilus DE filter. My question is how many positions are available and which position is backwash? Not sure but I think the model is "26-1165". Looks like this:
    http://www.poolpartsandsupplies.com/...headid=176.151
    Thanks for your input.
    Socal_biker Guest
    Default Re: backwash position for pentair 2" slide valve?
    Scanned from the manual that came with mine. The valve position is different for sand & D.E. filters.
    D.E. Filter
    Handle up = D.E. backwash
    Handle down = normal filtration flow
    Thanks for the info Socal_biker, but it only seems like I can only turn the handle left and right? There is an "open" and "lock" and right now I believe it's set in between those positions? Thanks again!
    Turning left and right merely locks or unlocks the valve in its present position. I think your O-ring inside the unit has become dry and is stuck. You may try disassembling and lubing the O-ring and see if you can get it to move up and down like it should.
  1. position of pool valve( with photos)?
    By vinouspleasure in forum Pool Equipment & Operations
    Last Post: 05-13-2013, 09:50 PM
  2. Pentair Backwash Valve
    By RStalls in forum In-Ground Pool Construction and Repair
    Last Post: 01-11-2012, 07:35 PM
  3. Pentair FNS filter - Hi-flow valve leaking out to backwash
    By naztuk in forum Pool Equipment & Operations
    Last Post: 11-03-2010, 05:46 PM
  4. Leaking slide valve?
    By cmcq in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2010, 11:24 AM
  5. Selector Valve Position?
    By colby in forum Pool Equipment & Operations
    Last Post: 09-08-2006, 11:49 PM
