Thread: Removing winter cover
    Question Removing winter cover
    Well, We are tired of looking at the blue winter cover,so we are making our 1st attempt at removing the solid winter cover . Any good tips about how to do this? I am going to the store to get lots of bleach and some baking soda(I have a box of borax from last year) . tahnks for any info.
    IMherDad is offline ** No working email address ** IMherDad 0
    Memphis, TN.
    Default Re: Removing winter cover
    Just make sure you get as much water off the cover as possible. You don't want that water getting back in your pool if possible. If you don't have a pump you can use a garden hose. Just toss one end on the cover and leave one end out in the yard. Take the end that is lying in your yard and suck the air out of it until the water begins to flow. Its a slow process but it does work.
    After that get at least two (more is better) people to help you slowly remove the cover off the pool and on to the grass or driveway. Once its off get an old mop and bucket and try to clean it as best as you can. Let it dry and then sprinkle some corn starch or baby powder on it and fold neatly.
    Pittsburgh, PA, USA.
    Quote Originally Posted by IMherDad
    What does corn startch / baby powder do?
    Another question -- My cover is very large (30 x 50 ft or so) -- and is hard to get completly dry after scrubbing. Any recommendations? Any thoughts on the cover deoderizer products, they don't mention it needs to be completely dry.
    Thanks again.
    Jim
    Glen Burnie, MD
    Quote Originally Posted by jmcst25
    Corn starch keeps the tarp from sticking together and dry rotting.
    Thanks 4 the info- the cover is off and packed away. Shocked the pool and vac twice. Water is clear but way cold 60 deg
    Cya
    Ed
  1. Problem removing strainer cover
    By imgamehere in forum Pool Equipment & Operations
    Last Post: 08-04-2011, 06:19 PM
  2. Solar Cover as Winter Cover?
    By CoffeeBean in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-02-2007, 11:46 AM
  3. Keeping water clean when removing a dirty solar cover???
    By gonefishin in forum Pool Equipment & Operations
    Last Post: 06-01-2006, 04:00 PM
  4. Stain at water line after removing cover
    By mwagner in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-27-2006, 09:45 AM
