Is there any procedure for testing the sand filter and pump for air leaks? Would using soapy water be the way? Any help would be greatly appreciated. The pool is not losing water. We are looking specifically for an air leak. Our pool has suddenly become really foamy (a blanket of foam is across the whole pool when the filter is running). All chemicals are in range. Thanks.
One other question: Is it okay to run the sand filter with only one valve open (we would have the pool drain valve open, and the leaf skimmer valve closed)?
) but I'd like to verify a leak as just a leak shouldn't result in foam across the whole surface. Is there any chance that some detergent got added to the pool? Have you used a 'non-polyquat' algicide?
- Waste
, which may have been the cause for any air in the pump. As for a chip off the corner, as long as it doesn't extend to the 'rib' on the cover you should still be able to fully seal the lid, unless it's a front corner and prevents the locking knobs from creating a full seat. I can't blame you for wanting to use up the Baq you had, that stuff isn't cheep, but do give a read like I said above. If you want to switch to a chlorine pool next year, I think the vast majority of people here would tell you that you are making a GREAT choice. As for salt water systems, I really like them and so do quite a few folks here. What you'll need to do (anytime between now and next spring) is to look into the SWG (SWCG) section of this forum, and see if it will be the right thing for your budget and pool (there should be a few 'cost analysis' of whether the unit actually saves money vs a bleach pool (it has a fairly high 'up-front' cost, some chems are still required to maintain the pool, cells need to be replaced periodicly and it costs electricity to run one) - but even so, the yearly cost will probably be less than a well maintained Baq pool. I've babbled enough for one post - if I can be of any further help, never hesitate to ask!
We did call the man that rebuilt our pool so I'm hoping he can get out in the next couple of days. Right now I have only the valve open that feeds from the bottom. Is it okay to run the pump like that for a while, with just the one valve open?
