Quote Originally Posted by ivyleager
I do believe with a new gunite/plaster pool you are going to have some fairly wild chemical fluctuations due to the curing of the plaster. Make sure to monitor the calcium hardness level; if not high enough some will begin leeching out of the wall.
These are also some excellent points applicable for a new gunite/plaster pool. Usually what happens during the curing process is that calcium hydroxide is produced so you find your Calcium Hardness (CH) increasing somewhat and your pH increasing quite a bit. Since currently Tri-Chlor tablets are being used, this is acidic and compensates for the "hydroxide" from the curing so that the combintation results in a relatively stable pH. As you point out, monitoring over time is important and getting the Calcium Hardness (CH) level checked is also important -- if no calcium was added at all to his pool water during startup, then that would indeed cause concern for etching or dissolving the new plaster (I would assume that the pool builder put in Calcium when initially filling the pool water, but you never know...).
So, Carl, please have your Calcium Hardness (CH) level checked when you get a chance and post your results.
Richard
