Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: HELP! Made BIG mistake!!
    DaBomb650 is offline ** No working email address ** DaBomb650 0
    Default HELP! Made BIG mistake!!
    I am a newby to these pools. Took sample to pool store today. Total alkal. was very high (225). They recomended adding 2 gallons of muratic acid after the days swimming. Added acid tonite, both gallons. THEN I read on the instructions only add 1 pint per day!!!
    OH MY GOD! I just put in 2 gallons!!!! WHAT DO I DO!!!
    PLEASE ANY ADVICE!!!!
    Beatrice, NE.
    Default Re: HELP! Made BIG mistake!!
    I just had a version of this happen . . . my son put muratic acid in instead of bleach!
    I'm sure the gurus will help you shortly, but from the thread detailing my problem ChemGeek noted "About a pound of Borax is equivalent to a cup of Muriatic Acid". You put in two gallons which is 32 cups, soooo you might try 32 pounds of 20 Mule Team Borax to put yourself back where you started from (it's cheap - about 75 cents a pound).
    BTW, acid isn't the way to deal with high total alkalinity . . . you lower the Ph and bubble air into the water and through the magic of chemistry your TA will fall and your Ph will rise. I believe there's a sticky note around here somewhere detailing the whole process.
    I've used a spare pump to make a fountain to put air in the water, it worked but was slow. Using a borrowed air compressor and an injection quil I made out of pvc I once lowered the TA in record time, so if you have an air compressor I'd recommend that route.
    While you're waiting for the gurus to chime in you should post some more specifics . . . what type of pool? How big of a pool? Are you using chlorine? Also, run a full gamut of tests and post the results (you do have a test kit . . . a drop based one, NOT test strips!).
    Good luck!
    Okay, thanks Steve. Here are my specifics. New (start up was last Thursday) 17,000 gunite/plaster pool.
    Test results before adding acid.
    Free chlorine - 1.3ppm
    Total Chlorine - 1.3ppm
    Combined chlorine - 0.0
    PH - 7.9
    hardness - not run
    alkalinity - 227ppm
    Cyanuric Acid - 10ppm
    Copper - not run
    Iron - 0ppm
    Total disolved solids - not run
    The pool is on an automatic clorinator with tri-clor tabs, and an ozonater.
    I added the acid per the instructions (as I understood them) from the person at the pool store that I had my water tested at. She informed me that this would have an affect on the ph and not to worry about that, that I needed to get the total alkalinity in line first, and then adjust the ph. Actually, I added LESS than the report sais to add. It recomended 2 gallons, 3 qts.
    The ph after testing with my drop test kit shows 6.8, but I don't know if this is as low as it wil indicate, or if that is what it really is.
    What I am woried about is damaging the new plaster.
    Carl.
    Carl,
    First of all, take a deep breath and relax. I'll let you know the probable effects of what you did and how you can fix it and others can chime in if I screw up or to give further assistance. You and your pool will get through this just fine.
    I calculate that with your pool numbers the 2 gallons of acid probably lowered your pool's pH down to 6.7 so that is not something to be overly concerned about. Since you are already down to that pH, you might as well follow Ben's procedure for lowering alkalinity where you have already started with the part about lowering pH and can start the aeration process and watch the pH rise. When the pH rises to the point that it's measureable on your test kit (i.e. at the level one higher than the lowest level on the test kit), then you can continue to aerate AND add acid to keep the pH low (per the procedure). Monitor your TA during this process and watch it drop until it reaches your target which should be around 100 (assuming you stop using Tri-Chlor tablets -- more on that later).
    Your CYA level is on the low side IF it were accurately measured, but I doubt very much that they measured this at 10 since the standard turbidity test normally stops at 30 (some go to 20). If your pool store used a colorimeter, then they could have measured the 10, but there have been reports on this forum of some pool stores reporting 100 minus the actual measurement (which would mean 90 in your case) so I'm concerned we don't really know what the true CYA level is. If you can get a test kit to measure this yourself, that would be best (I'm assuming you didn't do the CYA measurement yourself since the test kit doesn't show 10).
    Anyway, if you can let us know if 10 is the real CYA level then that would be helpful for determining the next step after you get your TA lowered. If your CYA is truly that low, then you can continue to use Tri-Chlor tablets in your automatic chlorinator for a while (you'll still need to add base, such as Borax, periodically since Tri-Chlor is quite acidic) until your CYA gets up to a higher level, probably at least 30. The actual level you should have is somewhat dependent on how much sunlight and chlorine loss you get each day, but generally the proper CYA will be in the range of 30-50 (I keep my CYA closer to 15, but I have an opaque pool cover and very low chlorine loss levels).
    After your CYA is at the proper level, you should stop using the Tri-Chlor tablets and switch to a liquid chlorine (sodium hypochlorite) source -- either chlorinating liquid which is concentrated chlorine or liquid bleach (Clorox Regular unscented or Clorox Ultra again unscented). You will not need to adjust your pH as much after switching to a liquid chlorine source.
    Hope this information helps.
    Richard
    Whewwww.......okay, breath in, breath out, I am calm, I am calm......hmmmmmmmmmmm.
    Okay, I (an now my wife, who is NOT happy about being woken up by the back door opening and closing) was SO woried about the low ph, she went ang got ALL the Borax they (Walmart) had, 2 boxes, and 2 boxed of baking soda 4 pounds. We added the baking soda to bring the ph somewhat back in line, about 6.9. We will keep the Borax just in case.
    After re-testing for the alkalinity, I measured it at about 260, so I have no idea who is correct, me or the pool store. I am going to take another sample to a different store tomorroww for another test.
    Thank you SO much for a quick response! I may have made a knee jerk reaction, but I had a mental picture of the plaster fallin off and ending up in th pottom of the deep end. I know, I know I crazy, maybe it is because it is 3:35 in the morning here!
    Anyway, what is more imprtant, alkalinity or ph?
    Carl.
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Don't add baking soda to raise ph. It's primary function is to raise ALKALINITY. Use Borax to raise pH and follow CarlD's instructions to lower alkalinity. Don't panic. These folks (moderators) on the forum really know their stuff. It's hard to do anything that will actually damage your pool, so relax. Please do follow their recommendations and you'll have great water before you know it. I've had crystal clear water for well over a year with NO algae since I began BBB. Just be patient until your pool reaches chemical equilibrium. Post often, and give your complete test data so they can give you the best instructions. Happy swimming!
    drband
    drband's Avatar
    Gainesville, GA
    Oops... I think the ALK lowering sticky is by Ben, not CarlD. In any case, look for it at the top of one of these forums.
    Okay, crap!
    Sounds like I made ANOTHER mistake! This morning, the ph is about the same, 6.8 or so, but my total alkalinity is about 300 ppm! Sounds like baking soda was the WRONG thing to add.
    The pool has a waterfall. Will this sub for the airation?
    I also have 2 boxes of borax (what I SHOULD have put in, instead of the baking soda). Should I add that?
    Central Texas
    I'm no pool expert, but I would resist the temptation to keep adding stuff. I know it makes us feel better to be -doing- something, but in this case you're making things worse. While the original alkalinity was a little high, it may not have caused any problems. Those pool store computer analysis sheets are programmed to make recommendations based on any variance from a standard set of parameter target ranges. They are also programmed to sell stuff you may not need.
    If I were you I would find a way to aerate the water as much as possible over the next few days. As the pool outgases the resultant CO2 from the acid, the pH will automatically rise and the alkalinity will fall. So you don't want to artificially raise the pH when you need it low to start this process to begin with.
    Given that you've just -raised- the alkalinity, plan on buying some more muriatic acid. Follow the directions posted at this forum to lower alkalinity - aerate, measure the pH and alkalinity, lower the pH if necessary, repeat as needed until the alkalinity is down where you want it.
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
    Beatrice, NE.
    Just follow chem_geek's advice . . . don't add anything, just bubble some air through the water and the TA will fall and the Ph will rise.
    I would imagine the water fall will work fine to bubble air into the water. If you have the ability though, make an injection quill out of some pvc (actually about anything would work - even an old garden hose with some tiny holes drilled in it and one end plugged and the other end hose clamped to an air line fitting) and hook up a large air compressor if you have one (those tiny ones you see to run nail guns, etc. wont work - they'll run and run and put very little air in the pool, they just don't have the capacity needed).
    Last year we had a 12' Intex above ground and I rigged a fountain up and it worked but was slow. Later one of the kids tried to climb up on the ring of the pool and let a ton of water out. After I refilled it the darn TA was high again. This time I hooked up an air compressor and it fell very quickly.
    Just calm down and follow the advice given and everything will work out.
    /Steve
  1. Customer made a bad mistake.....
    By Jasheon in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-22-2010, 10:41 AM
  2. I think I made a mistake
    By dagall in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-28-2007, 10:56 PM
  3. I think I almost made a Mistake!!!!
    By GA Mark in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-11-2006, 01:02 AM
  4. First mistake - added too much CYA
    By mshumack in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-06-2006, 10:28 PM
