Results 11 to 13 of 13
Thread: Bleach vs Cal Hypo.
    Default Re: Bleach vs Cal Hypo.
    Technically, both bleach and Cal-Hypo raise the TA when they raise the pH, but they do so in a way that the consumption of chlorine returns the pH and TA back to where it started.
    However, bleach does not increase CH whereas Cal-Hypo does. Cal-Hypo increases CH by 0.7 ppm for every 1 ppm in FC that it provides.
    Richard
    Now I got the whole formula now
    baking Soda : increase TA + PH
    Muriatic Acid: decrease PH
    Borax: increase PH
    3" tablet: increase Clorine + CYA
    flush/refill: decrease CYA or CH or anything too high
    (special procedure): decrease TA
    Cal+Hypo: increase CH
    Increase PH: Borax,
    Increasse PH + CH: Cal+Hypo
    Decreate PH: Muriatic Acid
    Increase CYA: 3" tablet
    decrease CYA: flush/refill
    Increase TA: baking soda + mutiatic acid
    Decrease TA: special procedure
    Do I miss any ?
    Don't need muriatic acid when increasing TA..just use baking soda. Your pH MAY rise but it will only be a very small amount....mine never does when adding baking soda. If you want to raise TA and pH at the same time, use soda ash, or Borax brand washing soda.
  1. swithing from cal hypo to bleach????
    By mspool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 12-31-2013, 01:08 PM
  2. difference between cal hypo and sodium hypo (from bleach)
    By kasatpoolforum in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-20-2010, 08:12 PM
  3. Bleach vs. Cal Hypo
    By CabanaMan in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-31-2006, 12:08 PM
  4. Switched from Cal Hypo to Bleach
    By Jakebear in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-26-2006, 06:45 PM
  5. cal hypo and bleach together?
    By scarywoody in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-25-2006, 03:16 PM
