You really need a good testing kit so you can do whatever tests you need whenever you need them. YOU can maintain consistency better than a pool store. Store results, from a trusted store, can be used as a backup, or "second opinion", if you will. Leslie's, where you shopped, should have a good drops-based test kit for CL, pH, TA, CA, and CYA. They should also have a kit that will test for FC, as well. The kit on the Pool Solutions site is the best, IMO, but the Leslie's one will do for now. Walmart also has a similar kit for about $15, but I don't believe it tests for FC, only total CL.
Yes, it's best to add your chlorine in the evening when it won't be bombarded by UV rays, but don't be afraid to add it at other times, if you really need it based on your test results.
