Chlorinate with Calcium Hypochlorite is the simplest if you're not in a hurry. Why do you think you need to? Test results would be very helpful.
I was wondering if anyone knows how to get the hardness up in an above ground pool. We are using a swg.
Thank you!
Lil Bit
The total hardness was 117 when tested and our chlorine is up too.
Thanks!
You do not need to increase calcium hardness.
