Can someone explain how to use the bleach calc.Boy I just don't get it.
also need to know if after adding bleach to my pool to I run it on filter or reculate,Im new to all this pool stuff,Boy I'm so glad I found this site
Belidna
Belidna
Enter your pool size in gallons. Enter the bleach strength as a whole number, enter 6% as 6. The strength of your bleach should be on the side of the bottle. It'll generally be either 5.25% or 6%.
Next you have to know how much increase you need. If your pool is at 0 PPM Cl and you want to get to 5 PPM, put 5 in the box that says "PPM increase desired". Click calculate. The box that says "bleach required" is how much bleach you need to pour in.
Run your filter on "filter" not recirculate. Won't do you much good otherwise!
Michael
Thanks for the help but I'm new to this not sure what cl is or means
ChlorineOriginally Posted by sisie5
I downloaded your bleach calculator.. you are saying enter "gallons".. the calc. says "L".. is that litres or gallons?Originally Posted by mwsmith2
Chuck
Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
Is there a bleach calc. that uses gallons for volume,.. and inches and feet for other measures? Instead of litres and meters.
I would have to say L is for Liters, but to help you out, there are 3.785L in 1 US Gal.
Go under More Calcs and then Settings to change the units from metric to imperial.
50,000 gallon vinyl IG located in Oklahoma.
- Korinian
Originally Posted by korinian
That makes perfect sense... I should have thought of that.. too impatient to look,.. I guess.
THANKS!
