Results 1 to 9 of 9
Thread: bleach calc
    sisie5 is offline Registered+ Thread Analyst sisie5 0
    franklin, in, us.
    Default bleach calc
    Can someone explain how to use the bleach calc.Boy I just don't get it.
    also need to know if after adding bleach to my pool to I run it on filter or reculate,Im new to all this pool stuff,Boy I'm so glad I found this site
    Belidna
    Katy, TX
    Default Re: bleach calc
    Enter your pool size in gallons. Enter the bleach strength as a whole number, enter 6% as 6. The strength of your bleach should be on the side of the bottle. It'll generally be either 5.25% or 6%.
    Next you have to know how much increase you need. If your pool is at 0 PPM Cl and you want to get to 5 PPM, put 5 in the box that says "PPM increase desired". Click calculate. The box that says "bleach required" is how much bleach you need to pour in.
    Run your filter on "filter" not recirculate. Won't do you much good otherwise!
    Michael
    franklin, in, us.
    Thanks for the help but I'm new to this not sure what cl is or means
    Indiana.
    Quote Originally Posted by sisie5
    Chlorine
    Tennessee.
    Quote Originally Posted by mwsmith2
    Michael
    I downloaded your bleach calculator.. you are saying enter "gallons".. the calc. says "L".. is that litres or gallons?
    Chuck
    Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
    Tennessee.
    Is there a bleach calc. that uses gallons for volume,.. and inches and feet for other measures? Instead of litres and meters.
    I would have to say L is for Liters, but to help you out, there are 3.785L in 1 US Gal.
    Oklahoma
    Go under More Calcs and then Settings to change the units from metric to imperial.
    50,000 gallon vinyl IG located in Oklahoma.
    - Korinian
    Tennessee.
    Quote Originally Posted by korinian
    That makes perfect sense... I should have thought of that.. too impatient to look,.. I guess.
    THANKS!
  1. bleach calc
    By Dmigz in forum Forum Q & A
    Last Post: 05-30-2014, 03:22 PM
  2. Bleach Calc Error
    By ePoolUser in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-01-2006, 08:02 PM
  3. bleach calc ??
    By geneskaf in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-14-2006, 06:15 PM
  4. Bleach Calc
    By michladny in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-14-2006, 12:54 PM
