Thread: BBB in a hot tub revisited.....
    Default Re: BBB in a hot tub revisited.....
    BBB should work fine in a hot tub....as far as the salt...My acrylic hot tub shares the same pump, filter and SWCG as my pool and my salt level is currently 3600 ppm with no ill effects. Except for the fact that my chlorine is generated by the SWCG and not by bleach I DO use the BBB method!
    Omaha
    BBB works fine in hot tubs. A tablespoon or so of bleach right after you use it every day is all you need.
    Never buying bromine tablets again.......
  1. Cost of SWCG vs Bleach - revisited
    By larry2338 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-17-2006, 06:30 PM
