Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: tds bogus or true???????
    turbottt1 Guest
    Default tds bogus or true???????
    Since he may see it here, I'm putting it here: "turbottt1" has been moved in to a 'banned' group, the "Bad Email Address" group, because his email address is dead. I use that group to prevent accidental emails from being sent to dead addresses, among other things. When emails bounce back to me, I automatically move users into that group. -Ben
    As the title says are total disolved solids measurements bogus or something to worry about???? I relate this towards our hot tub/spa. A couple of things before you answer. We have filled the tub with fresh water [ trucked in by a company that has been filling pools for 25yrs] added chems. [ bromine] used it twice and then been told to drain it because of high tds levels????? Second we had our water tested for tds and were told again to go home and drain it, but what we did was stayed out for four days only added the chems. to keep it within proper ranges took the very same water back in for another test. Guess what tds levels were fine??????? I thought that once these levels reach so high there's no way to lower them???? Were going to start here but by the end I would like to discuss some nasty chemical burns. thanks for all input. steve
    Default Re: tds bogus or true???????
    Hi Steve,
    Welcome to the forum (fancy meeting you here!)
    I'm sure others will jump in but for the most part TDS is a bogus measurement. The discrepancies you saw were probably testing errors at the pool store or dealer who did the test. If you drain and refill they can sell you more chems faster! Since your spa should be drained and refilled about every 3 months (depending on bather load) it is NOT an important measurement at all!
    TDS is one of those things that is only important when you have eliminated all the typical issues and still have a problem. Phosphates is another.
    If you cannot bring your pool under control using our main-line methods (adjusting pH, and T/A then hammering with bleach to keep at the shock level for the CYA level) THEN and only then do you turn to alternatives. First you check for metals, and then and only then do you bother exploring TDS or phosphates as the cause of your problems. (Note: TDS and phosphates are totally different issues).
    But pool stores, not being familiar with the PoolForum methods push stuff that requires unnecessary, extreme and usually EXPENSIVE measures without checking for the tried and true problems and solutions.
    99.9% of the time TDS is bogus. 1 time in a 1000 it's valid to explore it as the cause of your problems.
    turbottt1 Guest
    Thank you waterbear. I'm hoping thru this forum I can find a system that will work for me in the tub. I was not sure how to start so I thought I would eliminate one quick theory. [ tds] carld you hit the nail right on the head. I do have a problem. It's called a 2"x3" nasty spot just above my left ankle.[ chem. burn] It is related to just our spa. I can swim in the pool with no problems. originally sodium dichloro-s-triazinetrione, dihydrate now were on the simple bbb system. As far as our spa we use a two step program with bromine. [Artic brand] Might as well start at the beginning. First got the tub I noticed some itching right off the bat at this location. Being a newbie our first fill of water did not take long for us to distroy. The itching continued even with new water. Was told tds were causing my problem. [ after multi. drains and refills the problem is still there and much worse] I'm convinced it's related to the bromine. Has anybody else experienced anything like this???? For the record nobody else is effected by the water not family or friends and only this one spot. I can climb in and soak with no problems except for this lone spot?????? We had a suggestion just to add the proper amount of sodium bromide at fillup and use bleach to shock??? Can we just change the water and go with the b,b,b, system without any bromine??? Maybe other options on what to use for a sanitizer???? The dealers have told me that using chlor. in the spa is much harsher than bromine???? suggestion, help,advice????? waterbear please chime in as we have had this conversation many times. steve Fyi:: I do hope someday this site has a hot tub/spa section.
    Sanford, FL
    If you are the only one with this spot and you don't get it anywhere else - are you sure it's something caused by the spa and not some other skin infection that is aggravated by the spa- (staph or strep infection comes to mind). I am not a doctor - just logically wondering why it would only affect you and then only one part of your body.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Jul 2006
    Nova Scotia CANADA
    TRUE:
    I've been a beachcomber hot tub, ( similar to arctic spas), owner for three years.
    In my experience, yes TDS does matter.
    When the TDS gets too high, your chemicals will not work as effectively, meaning you must use a lot more to effectively sanitize.
    with conventional bromine or chlorine, after the sanitizer molecule burns up an organic particle, it turns into a bromamine or cloramine and thus leaves your hot tub with the cloudy, flat water ( if you have a lot of them... or high TDS).
    it also can aid in making your hot tub have bad odor.
    I'm not sure what the effect of a high TDS on your health might be...
    ( guess I should google it), but my guess would be that if your santizer isn't working as well then you leave yourself open for a multitude of possible health issues.
    I would recommend taking your water to a different( brand) dealer of Hot Tubs for a free testing ( for comparrison purposes)...
    I also suggest that you see your health professional.
    ( there is also a small possibility that you are allergic to bromine)
    BTW, personally I prefer my "tub ride" at a TDS of about 800-1000... that's when everything just feels "right"... ( I find that "fresh water" doesn't bubble that well...lol)
    The following is an article that I thought was interesting...
    good luck with your tub
    "TDS: Check it out when the water doesn't behave."
    By David Dickman
    Reprinted from Pool & Spa Service Industry News
    TDS - Total Dissolved Solids - may be the most misunderstood factor in the whole field of pool & spa water chemistry. It is misunderstood because no one knows exactly what effect it is going to have on any particular body of water.
    When everything else seems to be all right, and the water still acts screwy, check the TDS.
    High TDS can result in corrosion of metal equipment and accessories, even though the water is balanced.
    High TDS can cause eye and skin irritation, even though the pH is right and there are no chloramines in the water.
    High TDS can permit an algae bloom, even with a 2-3 ppm chlorine residual.
    But none of these symptoms will necessarily occur. It is the uncertain nature of problems caused by TDS that makes it such a headache to deal with.
    As its name states, TDS is the sum total of all of the dissolved things in a given body of water. It's everything in the water that's not actually water. It includes hardness, alkalinity, cyanuric acid, chlorides, bromides, sulfates, silicates, and all manner of organic compounds.
    Every time you add anything to the water, you are increasing its TDS. This includes not only sanitizing and pH adjusting chemicals, but also conditioner, algicides, and tile and surface cleaners. It includes airborne pollutants and bather waste as well as dissolved minerals in the fill water.
    At low levels, TDS does not present a problem. In fact, a certain amount of TDS is necessary for water balance. Hardness and Total Alkalinity are both part of TDS.
    But at high levels - above 3,000 parts per million - you are welcoming problems. The National Spa & Pool Institute, in its standards for both swimming pools and spas, recommends an ideal TDS of between 1,000 and 2,000 ppm, with a maximum of 3,000 ppm.
    No one knows exactly what mechanism is at work when you're dealing with high TDS water. One commonly held theory is that when you get a lot of dissolved substances in water, they interfere with the normal workings of sanitizers. They may do this by forming a chemical "shield" around bacteria, algae, and other substances normally attacked by chlorine or bromine. Or they may simply present "roadblocks" in the path of sanitizer molecules, preventing them from freely circulating.
    TDS buildup is inevitable. As we've explained, every time you add chemicals to water, you're increasing the TDS. When the water evaporates, it leaves behind all of the solids that had been dissolved in it.
    Just how much are you increasing the TDS when you chemically treat pool or spa water? Well, for every pound of dry chemical that you add to a 15,000 gallon pool, you are increasing the TDS by about 8 ppm.
    "Parts Per Million" is what scientists refer to as a "weight to weight" measurement. That is, if you know how much the water weighs, and you know how much the stuff you are adding to the water weighs, you can calculate how many parts per million you are adding to the water.
    As it happens, one gallon of water weighs 8.34 pounds. So if you know how many gallons are in a pool or spa, and you multiply that number by 8.34, you will know how many pounds of water are in the pool or spa.
    So, how many pounds of water are in a 450 gallon spa? The answer is 3,753 pounds (450 x 8.34 = 3,753). How about a 15,000 gallon pool? Well, 15,000 x 8.34 = 125,100. So, there are 125,100 pounds of water in a 15,000 gallon pool.
    OK, so now you know how much the water weighs. Now, take 1 million and divide it by the total weight of that water, and you will find out how many parts per million are contained in each pound of water. For example, 1,000,000/125,100 (pounds of water in our 15,000 gallon pool) = 7.99. We'll call it 8. That is, every pound of material added to a 15,000 gallon pool will contribute about 8 parts per million.
    How about our 450 gallon spa? Take 1,000,000, divide it by 3,753 (the weight of the water in the spa), and you get 266.45. We'll settle on 266. So for every pound of stuff that you add to a 450 gallon spa, you will be increasing the TDS by 266 parts per million.
    Effect of Dissolved Material on TDS - Pools
    (How Much 1 Pound of Material Will Raise TDS In Pools of Various Sizes)
    Pool Capacity
    TDS per 1 Pound
    5,000 gal. 24 ppm
    10,000 gal. 12 ppm
    15,000 gal. 8 ppm
    20,000 gal 6 ppm
    25,000 gal 4.8 ppm
    50,000 gal 2.4 ppm
    100,000 gal 1.2 ppm
    150,000 gal 0.8 ppm
    Effect of Dissolved Material on TDS - Spas
    Pool Capacity
    TDS per 1 Pound
    400 gal. 300 ppm
    450 gal. 266 ppm
    500 gal. 240 ppm
    550 gal 218 ppm
    600 gal 200 ppm
    650 gal 184 ppm
    700 gal 171 ppm
    750 gal 160 ppm
    The above charts should give you a pretty good idea of why TDS builds up so rapidly in spa water and also why the effect of chemical treatment is so dramatic when you are dealing with a spa. The accompanying charts - one for pools and the other for spas - will also give you an idea of how much of an impact 1 pound of chemical added to the water will have on TDS in vessels of different sizes.
    Incidentally, if you wanted to design a pool that would contain almost exactly 1 million pounds of water, it would be a 120,000 gallon vessel. In that pool, every 1 pound of solids dissolved in the water would increase the TDS by 1 ppm.
    Every sanitizing chemical, and every pH adjusting chemical used in the pool and spa industry will eventually contribute to the TDS in a pool or spa. Some will contribute more than others. Because sanitizing compounds often require the additonal use of pH adjusting chemicals, the chemical maintenance regimen you choose can have a dramatic effect on the buildup of TDS.
    TDS is fairly easy to calculate for dry chemicals. It's a bit more complicated for liquid solutions. If a research lab were going to test the solids content of a liquid, they would take a precise volume of the liquid and then slowly heat it until the liquid itself had evaporated. Then they would dry the remaining solids and weight them.
    The two most common liquid solutions used in our industry are muriatic acid and liquid chlorine (sodium hypochlorite). For your information, 1 gallon of muriatic acid will contribute 1.87 pounds of dissolved solids to the water. 1 gallon of liquid chlorine will contribute 2.2 pounds of dissolved solids.
    You should also understand that every type of chlorine & sanitizer - including gas chlorine - eventually ends up contributing to TDS in the form of chloride. So every time you add a pound of dry chlorine compound, or infuse a pound of gas chlorine into a 15,000 gallon pool, you will wind up increasing the TDS by about 8 ppm.
    TDS Testing
    Short of a detailed laboratory analysis, the most dependable method of TDS testing is through the use of a portable TDS meter. These meters actually measure the conductivity of the water - its ability to conduct an electrical charge, which happens to increase as the TDS increases.
    Hand-held TDS meters - usually in the $50.00 - $150.00 range, gggeenerally operate by either placing some water in a sample cell or dipping the meter directly in the pool water and pushing a button, which causes a small electric current to pass between two electrodes immersed in the water and separated by a specific distance.
    The meter measures the current passing between the electrodes and uses that to deter mine the water's conductivity, the meter dial (or LCD readout) is calibrated to indicate TDS in parts per million.
    The easieste way to reduce TDS is to drain the pool and refill it with fresh water. This can also be done in stages, taking the water level down 1 or 2 feet at a time and refilling over a period of days or weeks.
    Under normal circumstances, pool water can be expected to last anywhere from 3 to 5 years before it has to be completely changed. Your choice of chemical treatment can help to determine just how long it lasts.
    turbottt1 Guest
    First simmons99 you have a valid point. When the old doc has seen my leg it's been in full bloom and is in fact a serious chemical burn. I've just about got it cleared up maybe I'll go have it checked now. steve
    Regarding:
    Quote Originally Posted by RavenNS
    By David Dickman
    This is an excellent presentation of confusing information. [EDIT] No offense to RavenNS -- I'm referring to the article reprint only [END-EDIT]. To lump all TDS together is ridiculous. A sea water pool which has 30,000 to 40,000 TDS operates just fine so obviously it's not just high TDS that is the issue. When the TDS is composed mostly of simple salts, especially sodium and chloride, then this is not a problem (it does change water balance slightly, due to ionic strength). Most of the chemicals you add to your pool add sodium or chloride either immediately or when they get used up or broken down (i.e. chlorine). Carbonates that get added to your pool (sodium bicarbonate or sodium carbonate) do not build up because they are always outgassing as carbon dioxide to the air.
    On the other hand, organic material that gets into the pool and gets partly broken down by chlorine can sometimes stick around and not completely decompose. If the material is large enough, then it will get caught in the filter. If not, then it will remain dissolved. Now some of this organic material, if broken down into smaller molecules, can become food for bacteria and algae so that may explain why some higher TDS situations lead to what appears to be a reduction in sanitation or algae prevention (but is actually just that you don't have enough chlorine in the first place and were lucky that conditions for faster bacterial or algae growth weren't present). However, a conservative amount of chlorine (i.e. Ben's chart) should still work reliably in that environment. So while it may be true that a low TDS pool may be able to get away with a somewhat lower level of chlorine (below the minimums in Ben's chart, for example), I wouldn't say that a high TDS pool isn't manageable.
    As for the smell of water that is high in TDS and has not been changed in a spa, that is most likely the result of incomplete oxidation of organics and resulting chloramines (if chlorine is used as a sanitizer or if used in conjunction with bromine). It would be interesting to find out if shocking a spa with high chlorine levels would take care of this problem.
    In spite of what I just said, I think that regularly changing spa water makes a lot of sense since the quantity of organic material and bad stuff that gets put into the water is much, much larger per volume of water in a spa compared to a pool (even a commercial pool). If anyone has figured out how to maintain and shock such water so that they don't have to change it (or change it infrequently), then that would be useful information to know. As for pools, I believe they can go a lot longer without a water change, but in general you would end up doing some change of your pool water over time anyway through backwashing DE or sand filters. If you have a cartridge filter, then you probably have to manually drain and refill some pool water to refresh it periodically. In my own pool (which has a cartridge filter due to water restrictions in my area), I let each winter's rains effectively change about a third or so of the pool water (accounting for "continuous dilution").
    Richard
    Ft Lauderdale, Fl
    Sorry for the "sales pitch" but I mentioned that I would let you all know when a specific spa salt system was available...
    AutoPilot has now introduced the Spa Pilot. Using 1500 ppm, it is designed to maintain a NON-USE chlorine residual for spas up to 800 gallons. It works in conjunction with "Power Pouches" that are added one pouch before and one after (potassium Monopersulfate and other propriatary ingredients).
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    Poolsean, sounds like a winner to me! My spa is chlorinated by my SWG and it is really easy to maintain!
  1. Fix a Leak - is it too good to be true?
    By wishIcould in forum In-Ground Pool Construction and Repair
    Last Post: 05-29-2013, 01:45 PM
  2. CMU true 'Olympic sized' pool and pump room
    By mavswimmer in forum Photo Gallery
    Last Post: 06-17-2012, 08:42 PM
  3. Is it true? Stockings in skimmer can filter algae?
    By NullQwerty in forum Dealing with Algae & Slime
    Last Post: 05-30-2006, 10:57 PM
  4. Oval install & owner horror stories true?
    By NWMNMom in forum Above-Ground Pool Construction & Repair
    Last Post: 04-27-2006, 12:12 PM
