Thread: Skimmer install
    Dec 2005
    Royal Palm Beach, Florida, U.S..
    Default Skimmer install
    My pool came with vague instruction when it comes to skimmer and return install. I have the double sided skimmer gasket that attaches to the opening in the pool wall.
    Is this all that is required?Where does the liner fit into the picture? From
    my instructions, I see the sequence of parts,from inside the pool to outside,as
    skimmer cover plate,Liner,inside of double gasket,Pool Wall,outside of skimmer gasket,Skimmer body.Does this seem right? I thought there would be some sort of gasket between the skimmer cover plate and the pool liner,but my instructions don't show or mention one.Any help is greatly appreciated.
    John
    Default Re: Skimmer install
    Hi John, you got it right. The one piece gasket is made to protect the wall from rust. The only gasket truly needed to seal a skimmer or return is one between the liner and wall. The two gasket systems use one against the faceplate and one against the skimmer.
    They all seam to work just fine. The one you have will protect the wall the best over a long period of time.
    Best of luck, Dennis
    Dec 2005
    Thanks again Dennis.Your help and patience is always appreciated!
  1. Install Side Mount Skimmer to Intex Pool?
    By TheKs in forum Intex-type Pool Setup & Operations
    Last Post: 09-30-2012, 10:28 PM
  2. How the heck do I install a Hayward widemouth skimmer? SP1091WM
    By Dan264 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-19-2012, 09:31 PM
  3. How to repair an IG liner leak at the skimmer interface and replace skimmer
    By ralph in forum In-Ground Pool Construction and Repair
    Last Post: 02-29-2012, 10:37 AM
  4. Cannot figure out how to install a Hayward Skimmer Weir
    By Casey in forum In-Ground Pool Construction and Repair
    Last Post: 07-20-2011, 10:17 PM
  5. Should I install SWG myself???
    By Plane_guy in forum In-Ground Pool Construction and Repair
    Last Post: 06-29-2006, 01:17 PM
