Re: Some numbers .. Hardess ?
					I'm not afraid of chlorine but would like to run my SWCG at the lowest possible setting to maintain a healthy/ clear pool. This will extend the life of the cell and optimize my cost benefit of converting to the system.
My water is crystal clear but I turned the setting up a little on the system to get the chlorine into what is considered optimal around here. It's a new system so I am still dialing it in. If I can get the level up without running above about 60% I'll be happy .. Right now It's set at 45% and the preveiuous numbers posted above were with it set at about 30%.
			14'x31' kidney 21K gal IG plaster  pool; SWCG (Saline Generating System's SGS Breeze); Pentair FNS Plus 48 DE  DE filter; Whisperflow 1 HP pump; 8 hours hrs;  kit purchased from Ben; utility water; summer: none; winter: none; PF:5.7
